  • Total Topics: 15535
  • Online Today: 1340
Author Topic: Issues using WiFi with Mcafee VirusScan Enterprise 8.8  (Read 10762 times)
silverstone
« on: 30. January 2012., 15:07:08 »
Hello,
I have been using McAfee Virus Scan Enterprise 8.8 since a few years and never had a problem with it, until now!
Well I bought this wireless router to connect to internet using modem for my laptop and smartphone. But now every time i switch on the WiFi, i loose the connectivity after about 5 mins.
This may seem to be a network configuration problem or a router problem. But believe me i have everything setup right.
Recently i discovered that when i disable the "Access Protection" in Virusscan Console, i have no problem with the WiFi connection. After enabling the Access Protection, i again loose the WiFi connection.
I have no IPS or IDS or Firewall install.
Using McAfee VirusScan Enterprise + AntiSpyware Enterprise 8.8 with no patches.
Any help would be most appreciated.
Thanks
Re: Issues using WiFi with Mcafee VirusScan Enterprise 8.8
« Reply #1 on: 30. January 2012., 20:26:41 »
First apply Patch 1 and see if it keeps hapening, then you'll have to comment us hot did you set up your access protections rules
vishwanath99
« Reply #2 on: 31. January 2012., 08:29:45 »
open virus scan consol==>On-access scanner properties===>  blocking
Uncheck block
vishwanath99
« Reply #3 on: 31. January 2012., 10:00:31 »
by default block is enabled... Block the connection when a threat is detected
Check the on access protection statistics and also Log
Re: Mcafee blocks Wireless router - WiFi
« Reply #4 on: 31. January 2012., 17:17:48 »
Hi Silverstone, just want to check did you successfully apply Patch 1 and do you still have problem with WiFi??
silverstone
« Reply #5 on: 01. February 2012., 06:13:57 »
I did apply patch 1. Now the problem does not seems to be appearing.
I will test to for few days more with some continuous download.
Silverstone
silverstone
« Reply #6 on: 01. February 2012., 06:16:34 »
Uncheck block
But this option is to block the connection when a threat is detected in shared folder. Does this apply to a WiFi network?
I have no shared folders on my PC.
« Reply #7 on: 01. February 2012., 08:07:47 »
Silverstone
Ok, that is good news... ;)
silverstone
« Reply #8 on: 02. February 2012., 11:56:25 »
Thank yous guys.. seems the problem is no more occurring.
I did not wanted to switch to another antivirus as my friend suggested coz mcafee has been my support for more than 3 years now.
Thank you.  :thumbsup:
« Reply #9 on: 02. February 2012., 17:27:16 »
You welcome pal.
Just like me, I'm really big McAfee fan... mostly because of perpetual license for VSE. No worries about licenses, keys... and of course very good protection. ;)
Cheers!
