  • Total Topics: 16532
  • Online today: 3066
Guests: 3044
Total: 3046
Author Topic: Test Your FireWall Protection !!!  (Read 52405 times)
Payam20
Re: Test Your FireWall Protection !!!
« Reply #40 on: 07. January 2011., 21:23:57 »
Good test...Thanks!
Duar97
« Reply #41 on: 27. August 2011., 18:01:27 »
Hi...
I did the GRC test and the results were this:
GRC Port Authority Report created on UTC: 2011-08-27 at 16:53:31
Results from scan of ports: 0-1055
    1 Ports Open
    4 Ports Closed
 1051 Ports Stealth
 1056 Ports Tested
The port found to be OPEN was: 23
Ports found to be CLOSED were: 0, 1, 20, 21
Other than what is listed above, all ports are STEALTH.
TruStealth: FAILED - NOT all tested ports were STEALTH,
                   - NO unsolicited packets were received,
                   - A PING REPLY (ICMP Echo) WAS RECEIVED.
Can you help me... I'm using COMODO Firewall
Regards, Duar97
« Reply #42 on: 27. August 2011., 18:53:14 »
Download the Sysinternal suite and use TCPView to check witch application is listening on port 23.
J.
okbetsports
« Reply #43 on: 05. July 2022., 07:55:05 »
play and earn check this OKBET
