  • Total Topics: 16532
  • Online today: 3056
Guests: 2867
Total: 2870
Poll
how to remove recycler.exe
how to fix short cut folder?
0 (0%)
any software to remove this permanently?
0 (0%)
Total Members Voted: 0
Author Topic: recycler.exe  (Read 22547 times)
jade0220
Re: recycler.exe
« Reply #20 on: 15. February 2012., 01:24:56 »
thanks devnullius! be trying your option also...so do you suggest i change to  another anti virus?ad will it fix my shortcut folder and recycler problem?tnx alot
Re: recycler.exe
at last...here are the logs...
C:\Users\JACKSON0220\AppData\Roaming\IDM\DwnlData\JACKSON0220\chatvibes108_135\chatvibes108.exe   a variant of Win32/MessengerPlus.A application   deleted - quarantined
D:\applications\programs\Cyberlink POWER DIRECTOR Ultra v7.00.1628(NEW-with serial keys)\Cyberlink PowerDirector Ultra v7.00.1628.rar   probably a variant of Win32/Agent.JAMZZKT trojan   deleted - quarantined
D:\applications\utilities\Gamebooster 2.3 [Adrianus217].exe   a variant of Win32/Toolbar.Widgi application   deleted - quarantined
D:\applications\utilities\IObit GameBooster Premium 2.4.1.rar   a variant of Win32/Toolbar.Widgi application   deleted - quarantined
D:\applications\utilities\Advanced SystemCare Pro 4.0.1.200 Final ML Software + Serial Key\Advanced SystemCare Pro 4.0.1.200 Final ML Software + Serial Key.rar   a variant of Win32/Toolbar.Widgi application   deleted - quarantined
D:\applications\utilities\HDD Regenerator 2011\hr2011.exe   NSIS/TrojanDownloader.FakeAlert.DK trojan   deleted - quarantined
D:\downloads\dell\drivers\chatvibes108.exe   a variant of Win32/MessengerPlus.A application   deleted - quarantined
D:\downloads\Microsoft Office 2010 Activator [ kk ]\Microsoft Office 2010 Activator [ kk ].rar   Win32/HackKMS.A application   deleted - quarantined
F:\antivirus\bitdefender 2012\BitDefender 2012 Crack.rar   a variant of MSIL/Injector.JU trojan   deleted - quarantined
F:\applications\programs\Cyberlink PowerDirector Ultra v7.00.1628.rar   probably a variant of Win32/Agent.JAMZZKT trojan   deleted - quarantined
F:\applications\programs\Advanced SystemCare Pro 4.0.1.200 Final ML Software + Serial Key\Advanced SystemCare Pro 4.0.1.200 Final ML Software + Serial Key.rar   a variant of Win32/Toolbar.Widgi application   deleted - quarantined
F:\applications\programs\MS OFFICE PRO 2010\Microsoft Office 2010 Activator [ kk ]\Microsoft Office 2010 Activator [ kk ].rar   Win32/HackKMS.A application   deleted - quarantined
F:\applications\utilities\Gamebooster 2.3 [Adrianus217].exe   a variant of Win32/Toolbar.Widgi application   deleted - quarantined
F:\applications\utilities\Product Key_awal.rar   a variant of Win32/Toolbar.Widgi application   deleted - quarantined
F:\Autorun.inf\ImmunityFolder...\antivirus.lnk   Win32/Dorkbot.D worm   cleaned by deleting - quarantined
F:\OS\windows7\Crack\SLIC Dump ToolKit v2.0\SLIC_Dump_ToolKit.EXE   a variant of Win32/Packed.FlyStudio application   cleaned by deleting - quarantined
Jade, don't worry most of these things are irrelevant... IMO, this one, marked with red letters, cause all this mess. ;)
Lets go, after you finish with instructions provided by Devvie... follow my additonal instructions and after that provide us New logs from HJT and BitDefender Online Scaner:
1. Turn-Off System Restore:
Steps to turn off System Restore
1. Click Start, right-click My Computer, and then click Properties.
2. In the System Properties dialog box, click the System Restore tab.
3. Click to select the Turn off System Restore check box. Or, click to select the Turn off System Restore on all drives check box.
4. Click OK.
5. When you receive the following message, click Yes to confirm that you want to turn off System Restore:
You have chosen to turn off System Restore. If you continue, all existing restore points will be deleted, and you will not be able to track or undo changes to your computer.
Do you want to turn off System Restore?
After a few moments, the System Properties dialog box closes.
2. Go to Safe Mode with Networking option:
To start the computer in safe mode
1.
You should print these instructions before continuing. They will not be available after you shut your computer down in step 2.
2.
Click Start and then click Shut Down.
3.
In the drop-down list of the Shut Down Windows dialog box, click Restart, and then click OK.
4.
As your computer restarts but before Windows launches, press F8.
On a computer that is configured for booting to multiple operating systems, you can press F8 when the boot menu appears.
5.
Use the arrow keys to highlight the appropriate safe mode option, and then press ENTER.
6.
If you have a dual-boot or multiple-boot system, choose the installation that you need to access using the arrow keys, and then press ENTER.
Note•
If Windows launches before you can choose a safe mode, restart your computer and try again.
In safe mode, you have access to only basic files and drivers (mouse, monitor, keyboard, mass storage, base video, default system services, and no network connections). You can choose the Safe Mode with Networking option, which loads all of the above files and drivers and the essential services and drivers to start networking, or you can choose the Safe Mode with Command Prompt option, which is exactly the same as safe mode except that a command prompt is started instead of the graphical user interface. You can also choose Last Known Good Configuration, which starts your computer using the registry information that was saved at the last shutdown.
Safe mode helps you diagnose problems. If a symptom does not reappear when you start in safe mode, you can eliminate the default settings and minimum device drivers as possible causes. If a newly added device or a changed driver is causing problems, you can use safe mode to remove the device or reverse the change.
There are circumstances where safe mode will not be able to help you, such as when Windows system files that are required to start the system are corrupted or damaged. In this case, the Recovery Console may help you.
NUM LOCK must be off before the arrow keys on the numeric keypad will function.
3. Download and Run NOD32 AV Online Scaner (during Safe Mode): http://scforum.info/index.php/topic,734.0.html
4. Download and use CCleaner: http://scforum.info/index.php/topic,1133.0.html (be careful, select everything except Desktop Shortcuts & Hotfix Uninstallers)
5. As I mention at the start, provide us new logs and information did you still experience problems with your PC??
cya later,
Re: recycler.exe
« Reply #22 on: 16. February 2012., 11:27:46 »
Turning off system restore is smart - virus will hide there too (and it takes long to scan).
In cases like these, I do not trust NOD32 enough. I almost insist on Superantispyware. Run them both?
For which antivirus program to use in the future, see this thread (to be posted when I have time): http://scforum.info/index.php/topic,7429.0.html .
You have no use for CCleaner IF your run Cleanup! by Steven Gould. It does a better cleanup and scan. CCleaner's name stands for Crap Cleaner. I agree, it's a crap Cleaner ;p
On my systems, I use some custom scripts; when one is interested I'll post them online (with instructions).
Running Combofix creates a log which has all info and more. It combines all requested here, plus some extras... Should be enough, and it's only a single log to post ;p
Re: how to remove recycle folder - recycler.exe
« Reply #23 on: 16. February 2012., 12:02:52 »
@devnullius
It look that you didn't notice this part:  :P
@jade0220
Here you have "The Best AntiVirus" Topic: http://scforum.info/index.php/topic,100.0.html
and here you have The Best FREE AV - Avast, Avira, AVG, Panda (tested by SCF Team): http://scforum.info/index.php/board,10.0.html
Re: recycler.exe
« Reply #24 on: 17. February 2012., 09:56:01 »
I've seen it ; )) Two captains on one ship - we might still make it to port after all ; pp
Re: recycler.exe
« Reply #25 on: 17. February 2012., 16:52:05 »
In any case, We'll do that better than "Captain Coward": http://www.dailymail.co.uk/news/article-2087704/Costa-Concordia-Captain-Francesco-Schettino-I-left-I-FELL-lifeboat.html ;)
@Jade
My friend, We're still waiting reply from YOU ?!
