Before applying for license request, you should know that:1. If you need one year or lengthier subscription of F-Secure Internet Security 2013, you will need to use more than one email address.2. License request is being monitored through IP address tracking. This means one IP can get only one license at maximum.3. There is no country restriction means you can apply from anywhere in the world. You need to have internet access.4. As there is IP restriction, you will need to use different proxy services. Google can help you in this matter. Or if you want, you can use HotSpotShield which is free and reliable solution: http://www.hotspotshield.com/5. For each license request, you need to use the email which you have never registered with F-Secure.6. You will need to disconnect and connect HotSpotShield for each license request.
I tried to check this link but it is out of dateplease I need another solution to help memy device is not protected
