  • Online today: 88118
Guests: 67410
Total: 67414
Author Topic: Hard drive Failure (light flashing w/ Beeping sound) Recover Data?  (Read 6198 times)
ibu
Hi
I have a Seagate FreeAgent Go 880GB hard drive which i plugged in today it is giving me a sound along with flashing light.... Also the drive is not detectable in windows
I just want to recover data from this hard drive.
Can some one guide me on how to do this?
Re: Problems with Seagate FreeAgent Go
« Reply #1 on: 04. November 2012., 17:41:42 »
HI Ibu,
don't worry, We'll do our best to help you.  :bih:
For the start I need more information about this HDD:
- how this problem occur ?
- when did you last time used them ?
- did this disc work 100% properly at that time ?
- did you try to install something on them, format them, make a partition or something like that ??
Also, for quick help, here you have two "old" but very "similar" cases with very good advices:
http://scforum.info/index.php/topic,5722.0.html
http://scforum.info/index.php/topic,3399.0.html
First provide us additional information and after that try to resolve this problem with advices from these two Topics.
cya later,
ibu
Re: Hard drive Failure (light flashing w/ Beeping sound) Recover Data?
« Reply #2 on: 04. November 2012., 17:53:41 »
Thanks
BTW this is an external hard drive
(In case required here is the pic of the drive here is the pic of the drive)
- Last time I plugged in the drive it was working perfectly fine... today when i plugged in using three different cables its not working giving me the same beeping sound and flashing light... although i see my device manger displaying a driver as "intio combo default controller" when i plug in the hard drive
- last used less than a week
- yes it was working 100%
- No i didn't install, format or partition the drive
I will look at these cases two and see if i can find a solution out of it
jmoon
Thanks
Go to icare-recovery.com and download the free tool and scan it.  I have utilized this tool with pen drives and external usb drives when they are not detectable anymore and have worked great.  Test it out.
