Ok, your links definitely trigger my curiosity, although I think it is a dead-end. I've seen it over the years so many times, so many systems, ... I think it must be something very generic.
Still, here is the info
-- Physical Disk Information - Disk: #0: WDC WD800JD-75MSA3 --
Hard Disk Summary
Hard Disk Number . . . . . . . . . . . . . . . . : 0
Interface . . . . . . . . . . . . . . . . . . . : S-ATA II
Disk Controller . . . . . . . . . . . . . . . . : Intel(R) ICH8 4 port Serial ATA Storage Controller - 2820 (ATA)
Disk Location . . . . . . . . . . . . . . . . . : 0, Device: 0
Hard Disk Model ID . . . . . . . . . . . . . . . : WDC WD800JD-75MSA3
Firmware Revision . . . . . . . . . . . . . . . : 10.01E04
Hard Disk Serial Number . . . . . . . . . . . . : WD-WMAM9XV17506
Total Size . . . . . . . . . . . . . . . . . . . : 76293 MB
Power State . . . . . . . . . . . . . . . . . . : Active
Logical Drive(s) . . . . . . . . . . . . . . . . : C: []
Current Temperature . . . . . . . . . . . . . . : 36 °C
Power On Time . . . . . . . . . . . . . . . . . : 291 days, 12 hours
Estimated Remaining Lifetime . . . . . . . . . . : more than 1000 days
Health . . . . . . . . . . . . . . . . . . . . . : #################### 100 % (Excellent)
Performance . . . . . . . . . . . . . . . . . . : #################### 100 % (Excellent)
The hard disk status is PERFECT. Problematic or weak sectors were not found and there are no spin up or data transfer errors.
No actions needed.
ATA Information
Hard Disk Cylinders . . . . . . . . . . . . . . : 155010
Hard Disk Heads . . . . . . . . . . . . . . . . : 16
Hard Disk Sectors . . . . . . . . . . . . . . . : 63
ATA Revision . . . . . . . . . . . . . . . . . . : ATA/ATAPI-7
Total Sectors . . . . . . . . . . . . . . . . . : 156250000
Bytes Per Sector . . . . . . . . . . . . . . . . : 512
Buffer Size . . . . . . . . . . . . . . . . . . : 8192 KB
Multiple Sectors . . . . . . . . . . . . . . . . : 16
Error Correction Bytes . . . . . . . . . . . . . : 65
Unformatted Capacity . . . . . . . . . . . . . . : 76294 MB
Maximum PIO Mode . . . . . . . . . . . . . . . . : 4
Maximum Multiword DMA Mode . . . . . . . . . . . : 2
Maximum UDMA Mode . . . . . . . . . . . . . . . : 300 MB/s (6)
Active UDMA Mode . . . . . . . . . . . . . . . . : 300 MB/s (5)
Minimum Multiword DMA Transfer Time . . . . . . : 120 ns
Recommended Multiword DMA Transfer Time . . . . : 120 ns
Minimum PIO Transfer Time Without IORDY . . . . : 120 ns
Minimum PIO Transfer Time With IORDY . . . . . . : 120 ns
ATA Control Byte . . . . . . . . . . . . . . . . : Valid
ATA Checksum Value . . . . . . . . . . . . . . . : Valid
Acoustic Management Configuration
Acoustic Management . . . . . . . . . . . . . . : Supported
Acoustic Management . . . . . . . . . . . . . . : Disabled
Current Acoustic Level . . . . . . . . . . . . . : Min performance and volume (80h)
Recommended Acoustic Level . . . . . . . . . . . : Min performance and volume (80h)
ATA Features
Read Ahead Buffer . . . . . . . . . . . . . . . : Supported, Enabled
DMA . . . . . . . . . . . . . . . . . . . . . . : Supported
Ultra DMA . . . . . . . . . . . . . . . . . . . : Supported
S.M.A.R.T. . . . . . . . . . . . . . . . . . . . : Supported
Power Management . . . . . . . . . . . . . . . . : Supported
Write Cache . . . . . . . . . . . . . . . . . . : Supported
Host Protected Area . . . . . . . . . . . . . . : Supported
Advanced Power Management . . . . . . . . . . . : Not supported
Extended Power Management . . . . . . . . . . . : Not supported
Power Up In Standby . . . . . . . . . . . . . . : Not supported
48-Bit LBA Addressing . . . . . . . . . . . . . : Supported
Device Configuration Overlay . . . . . . . . . . : Supported
IORDY Support . . . . . . . . . . . . . . . . . : Supported
Read/Write DMA Queue . . . . . . . . . . . . . . : Not supported
NOP Command . . . . . . . . . . . . . . . . . . : Supported
Trusted Computing . . . . . . . . . . . . . . . : Not supported
64-Bit World Wide ID . . . . . . . . . . . . . . : Not supported
Streaming . . . . . . . . . . . . . . . . . . . : Not supported
Media Card Pass Through . . . . . . . . . . . . : Not supported
General Purpose Logging . . . . . . . . . . . . : Supported
Error Logging . . . . . . . . . . . . . . . . . : Supported
CFA Feature Set . . . . . . . . . . . . . . . . : Not supported
CFast Device . . . . . . . . . . . . . . . . . . : Not supported
Long Physical Sectors (1) . . . . . . . . . . . : Not supported
Long Logical Sectors . . . . . . . . . . . . . . : Not supported
Write-Read-Verify . . . . . . . . . . . . . . . : Not supported
NV Cache Feature . . . . . . . . . . . . . . . . : Not supported
NV Cache Power Mode . . . . . . . . . . . . . . : Not supported
NV Cache Size . . . . . . . . . . . . . . . . . : Not supported
Free-fall Control . . . . . . . . . . . . . . . : Not supported
Free-fall Control Sensitivity . . . . . . . . . : Not supported
SSD Features
Data Set Management . . . . . . . . . . . . . . : Not supported
TRIM Command . . . . . . . . . . . . . . . . . . : Not supported
Deterministic Read After TRIM . . . . . . . . . : Not supported
S.M.A.R.T. Details
Off-line Data Collection Status . . . . . . . . : Suspended By Interrupting Command From Host
Self Test Execution Status . . . . . . . . . . . : Successfully Completed
Total Time To Complete Off-line Data Collection : 2460 seconds
Execute Off-line Immediate . . . . . . . . . . . : Supported
Abort/restart Off-line By Host . . . . . . . . . : Not supported
Off-line Read Scanning . . . . . . . . . . . . . : Supported
Short Self-test . . . . . . . . . . . . . . . . : Supported
Extended Self-test . . . . . . . . . . . . . . . : Supported
Conveyance Self-test . . . . . . . . . . . . . . : Supported
Selective Self-Test . . . . . . . . . . . . . . : Supported
Save Data Before/After Power Saving Mode . . . . : Supported
Enable/Disable Attribute Autosave . . . . . . . : Supported
Error Logging Capability . . . . . . . . . . . . : Supported
Short Self-test Estimated Time . . . . . . . . . : 2 minutes
Extended Self-test Estimated Time . . . . . . . : 33 minutes
Conveyance Self-test Estimated Time . . . . . . : 6 minutes
Last Short Self-test Result . . . . . . . . . . : Never Started
Last Short Self-test Date . . . . . . . . . . . : Never Started
Last Extended Self-test Result . . . . . . . . . : Never Started
Last Extended Self-test Date . . . . . . . . . . : Never Started
Last Conveyance Self-test Result . . . . . . . . : Never Started
Last Conveyance Self-test Date . . . . . . . . . : Never Started
Security Mode
Security Mode . . . . . . . . . . . . . . . . . : Supported
Security Erase . . . . . . . . . . . . . . . . . : Not supported
Security Erase Time . . . . . . . . . . . . . . : Not supported
Security Enhanced Erase Feature . . . . . . . . : Not supported
Security Enhanced Erase Time . . . . . . . . . . : Not supported
Security Enabled . . . . . . . . . . . . . . . . : No
Security Locked . . . . . . . . . . . . . . . . : No
Security Frozen . . . . . . . . . . . . . . . . : Yes
Security Counter Expired . . . . . . . . . . . . : No
Security Level . . . . . . . . . . . . . . . . . : High
Serial ATA Features
S-ATA Compliance . . . . . . . . . . . . . . . . : Yes
S-ATA I Signaling Speed (1.5 Gps) . . . . . . . : Supported
S-ATA II Signaling Speed (3 Gps) . . . . . . . . : Supported
S-ATA Gen3 Signaling Speed (6 Gps) . . . . . . . : Not supported
Receipt Of Power Management Requests From Host . : Supported
PHY Event Counters . . . . . . . . . . . . . . . : Supported
Non-Zero Buffer Offsets In DMA Setup FIS . . . . : Not supported
DMA Setup Auto-Activate Optimization . . . . . . : Supported, Disabled
Device Initiating Interface Power Management . . : Supported, Disabled
In-Order Data Delivery . . . . . . . . . . . . . : Not supported
Asynchronous Notification . . . . . . . . . . . : Not supported
Software Settings Preservation . . . . . . . . . : Supported, Enabled
Native Command Queuing (NCQ) . . . . . . . . . . : Supported
Queue Length . . . . . . . . . . . . . . . . . . : 32
Disk Information
Disk Family . . . . . . . . . . . . . . . . . . : Caviar SE
Form Factor . . . . . . . . . . . . . . . . . . : 3.5"
Capacity . . . . . . . . . . . . . . . . . . . . : 80 GB (80 x 1.000.000.000 bytes)
Number Of Disks . . . . . . . . . . . . . . . . : ?
Number Of Heads . . . . . . . . . . . . . . . . : ?
Rotational Speed . . . . . . . . . . . . . . . . : 7200 RPM
Rotation Time . . . . . . . . . . . . . . . . . : 8,33 ms
Average Rotational Latency . . . . . . . . . . . : 4,17 ms
Disk Interface . . . . . . . . . . . . . . . . . : ?
Buffer-Host Max. Rate . . . . . . . . . . . . . : ? MB/seconds
Drive Ready Time (Typical) . . . . . . . . . . . : 9 seconds
Average Seek Time . . . . . . . . . . . . . . . : 8,9 ms
Track To Track Seek Time . . . . . . . . . . . . : 2,0 ms
Full Stroke Seek Time . . . . . . . . . . . . . : 21,0 ms
Width . . . . . . . . . . . . . . . . . . . . . : 101,6 mm (4,0 inch)
Depth . . . . . . . . . . . . . . . . . . . . . : 147,0 mm (5,8 inch)
Height . . . . . . . . . . . . . . . . . . . . . : 25,4 mm (1,0 inch)
Weight . . . . . . . . . . . . . . . . . . . . . : ? grams (0,0 pounds)
Required Power For Spinup . . . . . . . . . . . : ? mA
Power Required (Seek) . . . . . . . . . . . . . : ? W
Power Required (Idle) . . . . . . . . . . . . . : ? W
Power Required (Standby) . . . . . . . . . . . . : ? W
Manufacturer . . . . . . . . . . . . . . . . . . : Western Digital Corporation
Manufacturer Website . . . . . . . . . . . . . . :
http://www.westerndigital.com/en/products S.M.A.R.T.
No. Attribute Thre.. Value Worst Data Status Flags
1 Raw Read Error Rate 51 200 200 000000000000 OK Error-Rate, Performance, Statistical, Critical
3 Spin Up Time 21 165 163 000000000ABE OK Statistical, Critical
4 Start/Stop Count 0 99 99 000000000689 OK (Always passing) Self Preserving, Event Count, Statistical
5 Reallocated Sectors Co.. 140 200 200 000000000000 OK Self Preserving, Event Count, Statistical, Critical
7 Seek Error Rate 51 200 200 000000000000 OK Error-Rate, Performance, Statistical, Critical
9 Power On Time Count 0 91 91 000000001B54 OK (Always passing) Self Preserving, Event Count, Statistical
10 Spin Retry Count 51 100 100 000000000000 OK Event Count, Statistical, Critical
11 Drive Calibration Retr.. 51 100 100 000000000000 OK Event Count, Statistical
12 Drive Power Cycle Count 0 99 99 000000000689 OK (Always passing) Self Preserving, Event Count, Statistical
190 Airflow Temperature 45 64 47 000000000024 OK Self Preserving, Statistical
194 Disk Temperature 0 107 90 000000000024 OK (Always passing) Self Preserving, Statistical
196 Reallocation Event Count 0 200 200 000000000000 OK (Always passing) Self Preserving, Event Count, Statistical
197 Current Pending Sector.. 0 200 200 000000000000 OK (Always passing) Event Count, Statistical
198 Off-Line Uncorrectable.. 0 200 200 000000000000 OK (Always passing) Event Count
199 Ultra ATA CRC Error Co.. 0 200 200 000000000000 OK (Always passing) Self Preserving, Event Count, Error-Rate, Performanc..
200 Write Error Rate 51 200 200 000000000000 OK Error-Rate, Critical
Transfer Rate Information
Total Data Read . . . . . . . . . . . . . . . . : 319 MB, 73.925 MB since installation (5-3-2013)
Total Data Write . . . . . . . . . . . . . . . . : 158 MB, 103.627 MB since installation
Average Reads Per Day . . . . . . . . . . . . . : 73.925,00 MB
Average Writes Per Day . . . . . . . . . . . . . : 103.627,00 MB
Current Transfer Rate . . . . . . . . . . . . . : 2315 KB/s
Maximum Transfer Rate . . . . . . . . . . . . . : 20766 KB/s
Current Read Rate . . . . . . . . . . . . . . . : 1926 KB/s
Current Write Rate . . . . . . . . . . . . . . . : 389 KB/s
Current Disk Activity . . . . . . . . . . . . . : 32 %
Karma...
