  • Online today: 88118
Guests: 66336
Total: 66340
Author Topic: 4 pass disk wipe with bad blocks support  (Read 6518 times)
« on: 17. March 2013., 23:04:13 »
(misleading title, I know:)
Mostly for my own convenience, posted here.
When I have to check disk for errors OR if I have to wipe a disk with data, there is one tool I use.
I mostly attach the drive in question with a SATA/PATA to usb adapter  to my old PC which I boot with a live Ubuntu server disk OR even to my regular Windows PC with the adatper connected to a VMWare installation of Ubuntu Server x64.
Then, with mount and ls /dev/sd* I figure out which disk is which (to prevent accidents! :>).
Then, it's time to do some read/write testing.
Badblocks supports two modes: destructive read-write testing and non-destructive read/write testing.
non destructive read write command?
sudo badblocks -svn -c 250000 /dev/sdX
destructive, secure 4 pass pattern writing command?
sudo badblocks -svw -c 250000 /dev/sdX
For example:
badblocks -svn -c 250000 /dev/sdb
You might adjust the -c value. It tells you how many blocks (whatever:) can be scanned every pass. You need RAM to accommodate this feature :)
Karma,
~~~ notemail@facebook.com ~~~
Re: 4 pass disk wipe with bad blocks support
« Reply #1 on: 18. March 2013., 19:27:28 »
Nice!  :up:
« Reply #2 on: 04. June 2013., 12:03:06 »
IF repeated badblocks -svn /dev/sda keeps returning same errors, it is time to do a badblocks -svw /dev/sda - a destructive 4 pass read write test that will DESTROY all date FOREVER on your drive. So backup first maybe? ;p
This often will brush away errors not repaired by badblocks -svn ...
Karma,
« Reply #3 on: 20. January 2014., 20:41:16 »
Other solutions for secure hard disk wiping? Go here: http://scforum.info/index.php/topic,5474.msg22615.html#msg22615
