http://www.formatted-recovery.com/Copy Paste:
48 Hours Giveaway - iCare Format Recovery Pro
iCare Recovery offers time limited giveaway of its iCare Format Recovery to undelete, unformat data from hard disk, memory card, pen drive, USB, cellphone, camera...
Download url:
http://download.icare-recovery.com/format-giveaway.exeFree Code: 2G7333343A22E25D3EHH4AIL2WSB4G9F
format recovery software
Windows 7 Compatible
iCare Format Recovery v5.2
Free format recovery utility, iCare Format Recovery is able to restore files after formatted drive no matter quick format or complete format, or reformat twice...
It is also able to recover files from format related problems like drive has not been formatted, do you want to format it now error, chkdsk not available for raw drive error. raw file system error...
Windows 7, Vista, XP, 2000 and Server 2008, 2003, 2000 full compatible! The program can restore files from hard disk drive, external hard drive, memory card, digital camera card, cellphone card...
Download and run the program, have a cup of coffee and let iCare Format Recovery handle the rest!
Tech info... Also copy paste ; )
When can iCare Format Recovery help you restore files?
Formatted partition by mistake?
Reinstalled OS and reformatted the partition by accident?
Formatted Dynamic disk and then need files back?
Memory Card was formatted and need photo recovery?
RAW Drive and is reading 0 byte while there are lots of important files there?
Recover formatted HDD
NTFS format recovery
SD Card Format Recovery - iCare Format Recovery helps and you need to connect SD card to a PC and let it scan formatted SD Card
XD card not formatted error or xd card reformatted by accident
CF card has not formatted error or formatted by mistake
SanDisk sd card accidentally formatted or has not formatted problem
Western digital hard disk formatted, mator hard drive formatted, seagate hard drive formatted
iPod formatted recovery, iPhone* contact recovery, iPhone* format recovery (Here iPhone means jailbreak iPhone, if you are not sure, you may download the freeware to see whether it can recognize your iphone.)
more help here
Some errors that is beyond iCare Format Recovery
Here we would like to keep you informed that sometimes iCare Format Recovery is not able to perform a file recovery and besure to know the flause.
Disk has been physically damaged (disk fell onto the groud and broken into pieces) - At this time no data recovery software can help you out. The only solution is to send your disk to a data recovery service center.
New data were written to your drive/card (sometimes system would write data to your drive without your awareness)
Low level formatting (usually the format you did is regular format or full format, quick format which are within the recovery ablility. If you are not sure about this, be free to download free trial to test whether files can be restored.)
Reliable file recovery software
iCare Format Recovery is built with special file searching and reading engine. Anytime you find other program can locate or find more files that you lost than iCare Format Recovery, be free to let us know. You may enjoy a free license code. We are pretty sure that iCare Format Recovery recover the most files among all programs.
Free download format recovery software - iCare Format Recovery to perform file recovery after format, quick format data recovery, file recovery ntfs format, recovery data after format...
Dedicated in file recovery when drive has been formatted, encountered not formatted error, iCare Format Recovery is the very right solution if you just formatted your partition or card by mistake, drives or card reading "the drive is not formatted, do you want to format it now?". Recovering files after formatted FAT, NTFS partition with just a few clicks. What's more, it also recover deleted files emptied recycle bin, files from deleted partition.
Help me help you!
https://copy.com/?r=zOEhNk - Clear 15GB of cloud storage and...
... karma for you
~~~ notemail@facebook.com ~~~
