  • Total Topics: 16525
  • Online today: 2777
Guests: 2770
Total: 2771
Author Topic: Get Free iCare Data Recovery Standard Edition Worth $69.95USD  (Read 6359 times)
FROM: http://www.sparkindark.com/get-free-icare-data-recovery-standard-edition-worth-69-95usd.html
Written by Phanindra    | 0
iCare Data Recovery Standard works great in recovering the lost or deleted files from the system, even deleted from Recyle-Bin. It can easily recover files like photos, videos, office document,  image, music, email etc. It also supports recovery from almost many storage devices like hard drive, external hard drive, memory stick, memory card, USB drive, memory card, Zip, cf card,  SanDisk SD card, xd card, MicroSD card, pen stick, mini card . The advantage of this software is it can recover files lost during hard disk crash or system crash and also can get back files after a partitioning error like merging partitions failure, resizing partitions failure.
When you start the software , it has 4 types of search mechanisms depending on the type of recovery.
Lost Partition Recovery
It can be used in the following situations
deleted partition by mistake
bad partition table
partition lost without a reason
Advanced Files Recovery
SHIFT+DELETE command keys
partition inaccessible
emptied recycle bin
Deep Scan Recovery
system crashes
bad MBR, bad partition table, bad boot sector
bad file allocation table
software failure like merg partition failure, resize partition failure, ghost failure
RAID array damaged
Format Recovery
formatted partition, card etc by mistake
symptom – drive is not formatted, do you want to format it now
RAW file system, raw drive
CHKDSK is not available for RAW drive
Pressed restore button of iPod, iPhone, iTouch, blackberry
In case if you have reinstalled your Windows, no need to worry. iCare Data Recovery Standard software can still recover the files and also has the ability to recover RAID files even when raid gets damaged.
It supports Windows 8, 7, Vista, XP, 2000; Server 2008, 2003, 2000.
How To Get Free iCare Data Recovery Standard Edition Worth $69.95USD ?
Step 1 : Download the software from this link
Step 2 : Use the Free code:’82PZ7096N2W732G9N627RGQ9L7C7J28DX’, no quotation marks to register your copy.
Karma!!
~~~ notemail@facebook.com ~~~
Re: Get Free iCare Data Recovery Standard Edition Worth $69.95USD
« Reply #1 on: 31. March 2013., 00:03:58 »
What do you think, is this App better than Recuva: http://scforum.info/index.php/topic,3795.0.html
« Reply #2 on: 31. March 2013., 10:05:30 »
My experiences...? Often I find myself using 3 or 4 programs, for they all have their strengths and weaknesses. Never hurts having a second program lying around ; )
Actually... I now have collected over 30? 40? data recovery programs ;p
Karma
« Reply #3 on: 31. March 2013., 20:49:09 »
Are you kidding?  :o
« Reply #4 on: 01. April 2013., 08:00:17 »
Are you kidding?  :o
Honest to God ;p I started out with a warez collection but through the years I collected many many many giveaways :)
:) devnullius
« Reply #5 on: 01. April 2013., 18:26:45 »
Are you kidding?  :o
:) devnullius
I must admit, an impressive number.  :thumbsup:
« Reply #6 on: 02. April 2013., 20:29:09 »
I could image it for ya' and learn you how to use that image on different hardware? Only uploading will be the well-known b in the a ; )
Get Free iCare Format Recovery 5.2 (time limited giveaway)
« Reply #7 on: 19. August 2013., 20:37:26 »
Copy Paste:
48 Hours Giveaway - iCare Format Recovery Pro
iCare Recovery offers time limited giveaway of its iCare Format Recovery to undelete, unformat data from hard disk, memory card, pen drive, USB, cellphone, camera...
Download url: http://download.icare-recovery.com/format-giveaway.exe
Free Code: 2G7333343A22E25D3EHH4AIL2WSB4G9F
format recovery software
Windows 7 Compatible
iCare Format Recovery v5.2
Free format recovery utility, iCare Format Recovery is able to restore files after formatted drive no matter quick format or complete format, or reformat twice...
It is also able to recover files from format related problems like drive has not been formatted, do you want to format it now error, chkdsk not available for raw drive error. raw file system error...
Windows 7, Vista, XP, 2000 and Server 2008, 2003, 2000 full compatible! The program can restore files from hard disk drive, external hard drive, memory card, digital camera card, cellphone card...
Download and run the program, have a cup of coffee and let iCare Format Recovery handle the rest!
Tech info... Also copy paste ; )
When can iCare Format Recovery help you restore files?
Formatted partition by mistake?
Reinstalled OS and reformatted the partition by accident?
Formatted Dynamic disk and then need files back?
Memory Card was formatted and need photo recovery?
RAW Drive and is reading 0 byte while there are lots of important files there?
Recover formatted HDD
NTFS format recovery
SD Card Format Recovery - iCare Format Recovery helps and you need to connect SD card to a PC and let it scan formatted SD Card
XD card not formatted error or xd card reformatted by accident
CF card has not formatted error or formatted by mistake
SanDisk sd card accidentally formatted or has not formatted problem
Western digital hard disk formatted, mator hard drive formatted, seagate hard drive formatted
iPod formatted recovery, iPhone* contact recovery, iPhone* format recovery (Here iPhone means jailbreak iPhone, if you are not sure, you may download the freeware to see whether it can recognize your iphone.)
more help here
Some errors that is beyond iCare Format Recovery
Here we would like to keep you informed that sometimes iCare Format Recovery is not able to perform a file recovery and besure to know the flause.
Disk has been physically damaged (disk fell onto the groud and broken into pieces) - At this time no data recovery software can help you out. The only solution is to send your disk to a data recovery service center.
New data were written to your drive/card (sometimes system would write data to your drive without your awareness)
Low level formatting (usually the format you did is regular format or full format, quick format which are within the recovery ablility. If you are not sure about this, be free to download free trial to test whether files can be restored.)
Reliable file recovery software
iCare Format Recovery is built with special file searching and reading engine. Anytime you find other program can locate or find more files that you lost than iCare Format Recovery, be free to let us know. You may enjoy a free license code. We are pretty sure that iCare Format Recovery recover the most files among all programs.
Free download format recovery software - iCare Format Recovery to perform file recovery after format, quick format data recovery, file recovery ntfs format, recovery data after format...
Dedicated in file recovery when drive has been formatted, encountered not formatted error, iCare Format Recovery is the very right solution if you just formatted your partition or card by mistake, drives or card reading "the drive is not formatted, do you want to format it now?". Recovering files after formatted FAT, NTFS partition with just a few clicks. What's more, it also recover deleted files emptied recycle bin, files from deleted partition.
Help me help you! https://copy.com/?r=zOEhNk - Clear 15GB of cloud storage and... 
... karma for you :)
mikalonger
« Reply #8 on: 20. October 2014., 04:39:51 »
For all kinds of reason,you may lost data on your iPhone and iPad.Accidentally deleted files on your iPhone? Lost your iPhone data after updating your iPhone to iOS 8, or downgrading from iOS 8 to iOS 7? You iPhone was damaged or stolen, but you want your lost data back? Haven’t backup your iPhone before jailbreak and lost your data?No matter your device was lost,stolen or broken,you still have have to recover iPhone lost data.
Please don’t worry, - iPhone Data Recovery is the most professional ios data recovery software people to recover lost data back whatever your device is iPhone, iPad, or iPod touch. There are three ways for you: Directly restore data from your iPhone, recover from iTunes backup files or restore from iCloud backup files.
How to - restore iPhone after iOS 8 Upgrade
How to - recover data from iPhone 6
100% Compatible With: iPhone 6, iPhone 6 Plus, iPhone 5S/C, iPhone 5, iPhone 4S/4, iPhone 3GS, iPad and iPod touch.
Apply To:  iOS updata, iOS downgrade, iOS jailbreak, deletion, data loss, factory settings restored,device damaged
--- All links removed by Admin. ---
--- Member banned for 90 days, reason: SPAM! ---
