...Congratulations! Your spot has been reserved under billgates [at] scforum.info...
gmail is "." independent...So b.i.llgat.es [at] scforum.info == billgates [at] scforum.info.So forward shouldn't be needed?Correct me if I'm wrong ;pdevnulliusPS: 76620 People in front of you, 3018 People behind you
...... Google Apps does recognize dots......
...From Gmail Help:Gmail doesn't recognize dots as characters within usernames, you can add or remove the dots from a Gmail address without changing the actual destination address; they'll all go to your inbox, and only yours. In short:homerjsimpson@gmail.com = hom.er.j.sim.ps.on@gmail.comhomerjsimpson@gmail.com = HOMERJSIMPSON@gmail.comhomerjsimpson@gmail.com = Homer.J.Simpson@gmail.comAll these addresses belong to the same person. You can see this if you try to sign in with your username, but adding or removing a dot from it. You'll still go to your account....
"You learn something every day if you pay attention."~Ray LeBlond
