Thx Samker.
Some more info. Why it really is brilliant - especially when you understood your lessons Logic in high school? It makes triggers of about everything related to your phone. And you combine them into complexer forms to do "stuff" for you.
Some more copy pastes from the Google play Store:
Triggers:
• Any SMS Trigger - Triggers on SMS received
• SMS With Text Trigger - Triggers on receipt of SMS Message with a specific text
• Battery Level Trigger - Triggers on a defined battery level
• Bluetooth State Enabled/Disabled
• Bluetooth Device Connected - Any device or specific device
• Incoming/Hang Call - Any call or from a specific contact
• Headset Plugged/Unplugged Trigger
• Location Trigger - Arriving/Exiting a defined region
• External Power Connected/Disconnected
• Screen On/Off
• Wi-Fi Enabled/Disabled
• Connected to Wi-Fi network - Any network or a specific network
• Time Trigger - recurring time events
• GPS Enabled Changed - GPS Activated/Deactivated and started/stopped looking for current location
• SMS from contact
• USB Connected/Disconnected Trigger
• Airplane Mode Activated/Deactivated
• Dock State Trigger - Docked to Car/Desk
• Application Status Trigger - Triggers when selected application activated or deactivated
• Outgoing call - all calls or calling specific contact
• Sound Mode Changed to Silent/Vibrate/Normal
• Boot Trigger - triggers on device startup (assuming service starts on boot)
• Manual Trigger - Requires user explicit execution of this trigger
• Cell ID Trigger - Trigger when connecting or disconnecting from defined cellular cells
• NFC Trigger - use NFC tags to launch rules
• Weather Trigger - Monitor weather at your location
• Mobile Data State Trigger
• Activity Recognition - an EXPERIMENTAL trigger that detects when you are in a car, on a bicycle, on foot or standing still
Actions:
• Notification - Shows notification on notification bar
• Play Sound - Plays selected sound
• Set Bluetooth State - Enabled/Disabled
• Set Sound Mode - Silent / Vibrate / Normal (With/Without Vibrate)
• Set Speakerphone State - Turn on/off
• Set Volume - Sets volume of all streams or a specific stream
• Set Wi-Fi Adapter State - Enabled/Disabled
• Start Application
• Enable/Disable other rules
• Vibrate action
• Enable/Disable Data Connectivity action - [NOT supported on some devices - see why on developer website]
• Kill Application [Requires Root - see why on developer website]
• Launch Home Screen
• Activate/Deactivate Airplane mode [Supported for Android version prior to 4.2 and all rooted devices]
• Enable/Disable GPS [Supported for Android version prior to 2.3 and all rooted devices]
• Enable/Disable Sync
• Set Mobile Data - Enable/Disable Mobile Data
• Set Screen Brightness - Automatic or specific value
• Enable/Disable screen automatic rotation
• Dial Phone Number
• Send SMS to phone number
• Set screen timeout (Including "Never" turn off)
• Shutdown device [Requires Root]
• Text-to-Speech - Say defined text
• Reboot [Requires Root]
• Set Wallpaper - set your home screen wallpaper
Want to AutomateIt with your own language? visit
http://goo.gl/qpDoI.
Supports English, German, Spanish, Hebrew, Polish, Danish, French, Italian, Czech, Slovak, Romanian, Chinese, Hungarian, Portuguese, Japanese, Korean, Dutch and Russian
Some examples:
http://www.techrepublic.com/blog/smartphones/automate-your-android-smartphone-with-automateit-pro/7061-----
Wanna know more?? Click here:
http://automateitapp.com/-----
And I can attest from personal experiences the author really is fast with support. Let alone the Forum where you can go to!
So yeah...
K A R M A
~~~ notemail@facebook.com ~~~
