  • Total Topics: 12538
  • Online Today: 1099
Author Topic: 20h left! 1000 opentype (PC / Mac) fonts ($99 value)  (Read 2225 times)
« on: 29. September 2013., 12:48:44 »
FROM: https://www.bitsdujour.com/software/1000-opentype-fonts
LEADS TO: https://www.facebook.com/BitsDuJour/app_232331140144301
IMPORTANT: 128bit Technologies recommends only installing the fonts you plan on using. Installing a large number of fonts at once can* slow down your computer.
Copy Paste:
Finding compelling, one-of-a-kind fonts for use in your design and marketing collateral isn’t as easy as it sounds! You could spend days searching the Internet for fonts that tickle your fancy, and still come up empty. Today’s discount software promotion is a treasure trove of fonts that are free to use in all commercial applications – it’s 1000 OpenType Fonts!
1000 OpenType Fonts is a superb collection of fonts consisting of 238 unique font family styles and 1000 fonts in all. With 1000 OpenType Fonts, you’ll be able to supercharge your commercial endeavors, whether you’re in graphic design, web design, scrapbooking, or marketing. And since each font is in the OpenType format, you can use them freely across both Mac and PC computers. Need international character support? It’s in nearly every font in 1000 OpenType Fonts!
Best of all, the works that you create using 1000 OpenType Fonts are free of royalties, forever, so you’re free to use them as much as you want without worrying about writing any checks. Your purchase of 1000 OpenType Fonts grants you a commercial use license to install the fonts on up to five computers.
Don't have Facebook? That's ok, we haven't forgotten about you. Just click the 'Get It Free' button and fill out a quick survey to claim your 100% discount!
Today's 1000 OpenType Fonts discount promotion includes the following license types:
Windows Version ($99) ($0) Download MIRROR: box
Mac Version ($99) ($0) Download MIRROR: box
When you get it through BdJ you will receive a serial key for the license. The license isn't required to use the Windows fonts. The download is just that: fonts. BUT you will not be legally covered when you use these fonts... For Mac it is a different story. I found a png file that contains all fonts, but I could not extract that file without a key. The archive appears to be password protected. Apple fucks ;p But I'm working on it... So maybe I'll upload them later :)
... Karma!
~~~ notemail@facebook.com ~~~
* WILL slow down your computer. In fact, many fonts is one of the main reasons for a slow booting computer (Office...). Also see some interesting links in the reply... Or start googling right now: http://goo.gl/wX1F7Y
Windows, Fonts & Performance. What is true, what is false? You decide ;p
« Reply #1 on: 29. September 2013., 12:50:10 »
Some more details... As promissed in the original article
--> http://lifehacker.com/5821865/top-10-ways-to-speed-up-windows-boot-time
Since the dawn of time, Windows has loaded fonts at startup and slowed down the boot time. This is less of a problem than it used to be, but it can still slow you down a bit. Windows 7 loads over 200 fonts at startup; even more if you've installed Microsoft Office. Chances are, you use very few of those fonts, so you can hide them to speed up that process. In Windows 7, open up the Fonts folder from the Start Menu's search box, and check off all the fonts you don't need. Then click the "Hide" button in the toolbar. This way, if you ever want them, you can bring them back, but Windows won't load them at startup. Note that just removing a few fonts probably isn't going to make a noticeable difference—you'll probably need to get rid of a few hundred. That said, you might have hundreds more fonts installed than you realized, so that isn't as ridiculous as it sounds.P
--> http://superuser.com/questions/521001/does-installing-a-bunch-of-unnecessary-fonts-slow-computers-down
--> http://blog.tune-up.com/myth-buster/true-or-false-10-tweaks-to-speed-up-your-pcs-boot-time-part-1/
This article claims to debunk lots of myths. Some claims in this article I believe, but even then I often do not concur with his conclusions. Up to you ;p
Second part of the article makes more sense (https://blog.tune-up.com/myth-buster/true-or-false-10-tweaks-to-speed-up-your-pcs-boot-time-part-2/), but still. His numbers are SO constant - can't be true. Just test yourself. Without changing anything, measure cold boot, measure auto-reboot cycle and measure a cold boot when hardware is warm... You will see many fluctuations, if only because Windows itself keeps optimizing... Or testing ;p
--> http://social.technet.microsoft.com/Forums/windows/en-US/9482eee4-0a62-439a-9671-6603ed934faa/windows-7-very-slow-if-many-fonts-installed has some interesting user comments, including for management of large collections
--> troubleshooting fonts? http://www.brighthub.com/computing/windows-platform/articles/75583.aspx
