  • Total Topics: 14430
  • Online Today: 762
Author Topic: New Linux worm atacks on "Internet of Things" (Linux.Darlloz)  (Read 1852 times)
Symantec has stumbled across a worm that exploits various vulnerabilities in PHP to infect Intel x86-powered Linux devices. The security biz says the malware threatens to compromise home broadband routers and similar equipment.
However, home internet kit with x86 chips are few and far between – most network-connected embedded devices are powered by ARM or MIPS processors – so the threat seems almost non-existent.
But the security company claims that ARM and MIPS flavours of the Linux worm may be available, which could compromise broadband routers, TV set-top boxes, and similar gadgets now referred to as the "Internet of Things": http://resources.infosecinstitute.com/privacy-implications-internet-things/
The software nasty attempts to use username and password pairs commonly used to log into home internet gear while compromising a device.
Specifically, the software nasty Linux.Darlloz: http://www.symantec.com/security_response/writeup.jsp?docid=2013-112710-1612-99&tabid=2 takes advantage of web servers running PHP that can't grok query strings safely, allowing an attacker to execute arbitrary commands: http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-2336
Once a system is infected, the worm scans the network for other systems running a web server and PHP. It then tries to compromise those devices by exploiting PHP to download and run an ELF x86 binary – if necessary, logging in with trivial username-password pairs such as admin-admin, as found in poorly secured broadband routers and similar kit. Once running on the newly infiltrated gadget, the worm kills off access to any telnet services running.
The malware does not appear to perform any malicious activity other than silently spreading itself and wiping a load of system files. Again, this software is built for x86 processors, which aren't really used widely in embedded kit, but ARM, PPC and MIPS versions may be available to download that will be more effective at targeting equipment present in millions of homes.
"Many users may not be aware that they are using vulnerable devices in their homes or offices," Symantec's Kaoru Hayashi wrote in a report about the malicious code.
"Another issue we could face is that even if users notice vulnerable devices, no updates have been provided to some products by the vendor, because of outdated technology or hardware limitations, such as not having enough memory or a CPU that is too slow to support new versions of the software."
To protect devices from attack, the company recommends users and administrators put basic security protections in place, such as changing device passwords from default settings, updating software and firmware on their devices, and monitoring network connections and architecture.
You can find more technical details here on Symantec's blog: http://www.symantec.com/connect/blogs/linux-worm-targeting-hidden-devices
