  • Total Topics: 16976
  • Online today: 149186
Guests: 138172
Total: 138174
Author Topic: android 4.3 problem connecting wifi: certificate expired  (Read 27908 times)
0 Members and 62 Guests are viewing this topic.
« on: 03. December 2013., 01:01:56 »
I encountered this yesterday late, suddenly.
Tried a lot of things on my android (Windows clients were fine), I gave up - frustrated.
Today, only late at night I could test again. Result? No more problems.
So my solved / fixed / solution? Either reset your router (I did not do that due to uninterrupted-internet-demand) OR wait until your lease has expired without connecting your droid with wifi (dhcp lease depends on your router settings) OR connect to Guest wifi. That one still works too - no certificate, no security.
I do  not know what caused it - I'm only happy that it works again!
For Dirk
Amen.
Re: android 4.3 problem connecting wifi: you have to login again
« Reply #1 on: 03. December 2013., 19:19:30 »
Today, I have problems again with Wifi. Only my Droid :s
Connection with "Network Name': disconnected network connection. You have to login again.
(this is a rough translation. Original Dutch error: Verbinding met "Netwerk naam": De verbinding met dit netwerk is verbroken. U moet opnieuw inloggen.)
When I look at the wifi settings, "Network name" has a connection status of 'connected' and Internet actually works.
Keeping an eye on this sudden strange problem. So far, I loved Android 4.3 on my Samsung Galaxy Siii i9300.
Karma?
Re: android 4.3 problem connecting wifi: certificate expired
« Reply #2 on: 03. December 2013., 19:28:33 »
« Reply #3 on: 04. December 2013., 10:02:34 »
I don't think so - it was a wifi problem, not an app problem...?
We'll see how it remains. For now, all is ok.
Karma!
« Reply #4 on: 05. December 2013., 19:11:24 »
Hmm... It's becoming an evening ritual :(
Roughly translated:
"Connection with 'network name'...
This network is not available. Your certificate has expired"
(Original Dutch message:
Verbinding met 'netwerk naam'...
Dit netwerk is niet beschikbaar. Uw certificering is verlopen)
Yesterday I could just re-connect. Hope it will be the same today :)
When I go to the Wi-Fi network overview, my network has a strange detail. Where other networks show "Secured <encryption type>", MY wi-fi network shows: Login required (Dutch: "inloggen is verplicht").
When I press to connect, today it goes fine. But originally, the first day, a browser-choice window would popup and re-direct me to a custom Google search URL (defaulting to a blank search; nothing to login).
And even stranger... At night I disconnect network completely for a couple of hours (4 to 5). During the day everything stays stable. Only in the evening the problem appears. After re-connecting, the problem will re-appear. Sometimes almost instantly, sometimes it works for a while. Still, the evening remains troublesome.
Login makes no sense. It's just basic wifi router: no special functionality enabled...
Strange voodoo. I'll repost tomorrow ;p
No karma!
« Reply #5 on: 05. December 2013., 19:59:16 »
Uhm... does that network have a RADIUS server?
« Reply #6 on: 05. December 2013., 21:25:14 »
Thread updated. But: no :)
D.
I still haven't solved this problem.
The timing has changed. So at first I thought it was a router/dhcp problem (lease on 30 mins). But I always used those settings. Coíncidently I was also changing options on my wifi. I changed them back (channel, auto, stuff like that), but it did not change anything (nor should it).
The first certificate warning takes a while to appear. Then they slowly become more and more frequent until upto a point where I MUST connect to unprotected wifi.
Chrome on windows learned me that virii can cause strange behaviour like this.
I also have a lot of problems with the unlock screen. Often it will just not react anymore. Only a black display (and maybe a blinking led). Also my AutomateIt voices were often stuttering like the phone was under very high CPU/RAM load. I did not have these problems from the beginning but combined with the fact that the phone sometimes just reboots or needs a battery eject... Starts to sound a lot like the infamous Samsung 4.3 roll-out:
- http://www.androidpit.com/android-4-3-s3-update-causing-problems
- http://www.gottabemobile.com/2013/11/12/samsung-galaxy-s3-android-4-3-update-problems-emerge/
And yes, at times I also experience an EXCESSIVE battery drain. Usually I notice tthe emptied battery problem being followed by a non-responding lock screen (or reboot; or virtually non-responding).
And lastly, pressing home when (just) being locked could also be a cause instead of a symptom... :S
So things to do:
1. router reset (did not do that yet - only android has problems and my mini-mining-rigg cannot be disconnected. Maybe in 10 years or so ; -)
2. check for virii. I am currently installing al major (and unmajor) antivirus programs. I got some warnings, one or two that I could not easily explain. Of course I just removed anything I wasn't sure of. Still, the unlock problem remains - and I even unplugged the battery once more :(
3. new firmware. Starting the beginning of December (on Real Santa Claus Day to be exact;) Samsung has started rolling out new firmwares again (after being discontinued for a month).
BEFORE I do the new firmware, I FIRST will test by restore current system ROM. I expect it not to wipe my apps and icons (but that's a gamble I still do not fully understand;p).
So not over, not by a long shot :)
No karma
~~~ notemail@facebook.com ~~~
PS: also hinting on virus infection is the fact that I was checking and installing the November 2013 torrents for rebuilding my phone.
PS: I shortly also suspected my ADB tools (wifi && lock protector). But I used those programs almost from the beginning...
PS: Avast was installed al the way through; including Lost & Found :) I removed that too, but it did not change much. Also, on PC downloading torrents, Avast was active. And Zemana AntiLogger.
« Reply #8 on: 14. December 2013., 02:13:59 »
Sounds like a faulty stock rom... Samsung did it again.
Maybe you'll want to look at CyanogenMod official releases
« Reply #9 on: 14. December 2013., 09:36:51 »
