  • Total Topics: 16532
  • Online today: 3056
Guests: 2911
Total: 2914
Author Topic: android 4.3 problem connecting wifi: certificate expired  (Read 20446 times)
Re: android 4.3 problem connecting wifi: certificate expired
« Reply #10 on: 21. December 2013., 18:38:17 »
Do as you preach... Feedback!
Ok, as you might remember, I had a lot of problems with my phone...
1. certificate error... After setting an option back on my wifi router, I got two more errors and disconnects. Both not followed by successive disconnects. So far so good! I'll change options once more to get to the bottom of this, because... See 2. :)
2. virii! While I was protected by Avast (Windows/Android) all the way and I should have been clean, I'm now almost certain I wasn't. What I did was "just" installing different antivirus programs to let them scan and then I'd install the next, and the next, and, ... These were my initial choices:
Dr. Web v7 Light first, then McAfee (trial), Kaspersky, AVG Free, Creative Apps' Antivirus Free, AVL Pro App, Norton Mobile, 360 Mobile Security, Malwarebytes Anti-Malware and just to be sure I finished with Avira Free - which came tested very good. See Perfect Scoring Android Antivirus Programs here: http://scforum.info/index.php/topic,8519.msg21947.html#msg21947 .
I only found this list after all my scanning had been done.
All problems were solved after all these scans (except 2 more certificate errors). Problems remaining was: see 3 :)
3. lock screen is very sluggish. This problem became less but remained a problem. I could improve it a little more by removing NotifierPro from Security - Notification Access... though.
And as far as I could tell I had this problem even before all warez-troubles I caused, so I blamed it on nasty stock rom (I9300XXUGMJ9_I9300VFGGMJ5_I9300BUUGMJ3_HOME.tar.md5)*. After a week or so I decided today to re-Odin this firmware once more. Luckily, this rom keeps all apps and home screens intact. Now, the lockscreen lag has become even less. BUT I (sometimes) still have stuttering voices when AutomateIT Pro (4.0.72) needs to tell me something. Voices continues normally as soon as I the screen is unlocked. I can live with that :)
4. random crash & reboots went back to "normal" - must be firmware problem. Sometimes the Samsung logo will stutter too - it's a nasty bug, hidden deep within ;p
5. non-responding phone / black screen. Only unplugging the battery (and waiting 30 seconds!) would solve this. Problem largely solved. They computers in the end ; -)
6. crash & burn. Sometimes 5. above would be combined with a massive battery drain. Say 10s of procents in half an hour! That seems to have been solved - I did not see this appear anymore.
I now made another Nandroid backup and am going to try this firmware: I9300XXUGMK6_I9300OXAGMK6_OXA.zip (FROM: http://android.sc/update-galaxy-s3-i9300-to-official-android-4-3-xxugmk6-jelly-bean-firmware/). Hopefully the (still not officially confirmed) i9300 roll-out bugs are then finally solved :)
For now, I consider my problems solved, largely by just running many antivirus apps! Lesson learned; no one antivirus solution on android is "perfect". They are only lucky on certain test sets...
I'll update about the certificate error once more - say in a week?
Karma,
* How to root Samsung Galaxy siii s3 i9300 international with 4.3 (stock) firmware? I only found one working solution: flashing with Odin! I used CF-Auto-Root-m0-m0xx-gti9300.zip (SOURCE: http://www.ibtimes.co.uk/galaxys3-i9300-root-android43-jellybean-update-howto-521949). This rooting worked on both my 4.3 firmwares... [/s] These rooting instructions actually make your phone unstable! Updated instructions: http://scforum.info/index.php/topic,8536.msg21990.html#msg21990
« Reply #11 on: 22. December 2013., 00:10:34 »
5 & 6 are kernel-related problems :p
The struttering is due to low CPU freq sometimes
« Reply #12 on: 22. December 2013., 08:43:36 »
Oooh, that could be a VERY good explanation for the stuttering... Low CPU frequency! I'll (try to) check this out further.
Thanx!
PS: I agree with 5 & 6 ; )
« Reply #13 on: 22. December 2013., 15:59:28 »
Stock samsung Kenel is always very bad lol.
I read somewhere in XDA Developers that the S3 has a bug in which the CPU would lower its freq and cause trouble.. I don't remember much about the issue
« Reply #14 on: 22. December 2013., 17:39:14 »
I must say... A few hours into the december 4.3 build... I think I FINALLY have a phone without apparent bugs!  All runs smooth. Locked, unlocked, plenty of free RAM, all programs start, no reboots yet, no maximum amount of installed apps, ...
This is sad, but I'm happy for now :)
Karma!
« Reply #15 on: 22. December 2013., 17:43:39 »
Had you ever tried CM on it? :p
Or AOSP?
« Reply #16 on: 22. December 2013., 18:33:13 »
Or AOSP?
Ooooh yes, don't you worry. Of course I did. It would be far superior and cooler and all that. I searched and found many custom roms from different 'people' or entities... High user ratings, special attention to details and performance, ... You name it!
In reality, I ended up with horrible wifi connections and other even more horrible sheit. Noooo good. It's then that I decided that only Samsung could make Samsung phone ROMs ;p
No more - ever! Or at least, till I have the Galaxy vi ; -)
« Reply #17 on: 22. December 2013., 18:39:13 »
S4 is having some trouble from what I heard :p
Uhm.. I dunno, I'm using CM10.1 on my Ace and It's far superior to Samsung's stock. even Official CM7.2 beated stock rom.
I flashed CM10.2 on one of my friend's S3 and many of the problem he was having with the stock rom dissapeared :p
« Reply #18 on: 22. December 2013., 19:50:28 »
That's why I wait for Galaxy vi ;p
Maybe it's time to give them a new look one of these years, but for now I seem to be happy (and I'm left wondering... Which problems did your friend get in return, without noticing them as bugs...)
« Reply #19 on: 22. December 2013., 20:50:42 »
You might find this interesting... "Only Google have possibility to automatically protect Android phones ?!": http://scforum.info/index.php/topic,8539.0.html
