  • Total Topics: 16523
  • Online today: 2717
Guests: 2709
Total: 2710
Author Topic: 40h left!! supereasy 1-click backup for free v1.13.0_8099 (TIP! Looks good...)  (Read 5580 times)
SOURCE: http://sharewareonsale.com/s/supereasy-1-click-backup-sale
Free SuperEasy 1-Click Backup (100% discount)
$19.95 Free!
SuperEasy 1-Click Backup is a drive-level image backup utility that aims to simplify the creation of system backups; set it up to backup whatever drives or partitions you want and it works intelligently in the background creating your backups.
It has support for full or selective restore and has the ability to create bootable recovery disc.
Limited time offer! Sale ends in 1 days 16 hours 12 mins
HOW TO DOWNLOAD AND REGISTER THIS OFFER
Before we tell you how to get this freebie, please take note the terms and conditions of this specific giveaway allow you to install or re-install whenever you want. However, you need to download the installer and get your license/registration key before the offer has ended.
That said, the download link for SuperEasy 1-Click Backup can be found on the giveaway page.
Download SuperEasy 1-Click Backup and install it.
Once installed, run SuperEasy 1-Click Backup and you will be prompted with a “License Activation” screen.
Folllow on-screen instructions at that screen to register SuperEasy 1-Click Backup. You may have to run as admin if you are on Vista, Windows 7, and Windows 8.
All Features, Copy Paste FROM: https://www.supereasy.net/en/usd/pde/0021/products/SuperEasy-1-Click-Backup
* Complete system backup (image file)
* Recovery disc
* 1-Click setup
* Faster backup routine
* Versioning
* Intelligent pause mechanism
* Backup to network drives
* Backup to locally connected hard disks and USB flash drives
* Backup open files
* Selectively restore files and folders
* Fully-automated backups as background tasks
* Pause/continue even after system reboot
* Backup scheduler
* Incremental backups
* File compression
Supported languages: German English France Portuguese Italian Spanish
System requirements:  Windows XP Service Pack 1/ Windows Vista (32/64) / Windows 7 (32/64) / Windows® 8
.. Karma!
~~~ notemail@facebook.com ~~~
FROM: http://www.supereasy.net/en/eur/lpa/RescueDisk?utm_content=rescuedisc%2Fen&utm_medium=go&utm_source=sez1cb%2F8099
SuperEasy BackUp Rescue Disc
The rescue system is intended for two kinds of situations:
To restore a backup to your main hard disk. This cannot be done while your normal system is running, so you need the rescue system for that.
To restore a backup when your system is so damaged that it does not start anymore.
Important: The rescue system can only be used to restore image based backups at the moment. I.e. complete backups of one or more hard disks.
Creating the SuperEasy Backup Rescue Disc
To create the SuperEasy Backup Rescue Disc you need to follow these steps:
Download the contents of the CD (ZIP file):
For computers with the Windows 8 logo or UEFI firmware: http://supereasy.downloadcluster.com/supereasy/0023/rescuedisc-ubuntu_13.04-sezrs-64bit.iso
For all other computers: http://supereasy.downloadcluster.com/supereasy/0023/rescuedisc-ubuntu_13.04-sezrs-32bit.iso
MIRROR for BOTH: https://app.box.com/s/1at32qe98zq7dg4zvuru
Extract the downloaded file (supereasy_rescue_disc_archive) by right-clicking on it and selecting "Extract All". Then follow the instructions in the window that opens.
A file called "supereasy_rescue_disc.iso" should now have been extracted. It contains the rescue CD data.
Burn the downloaded CD data to a CD. It is very important that you use a burning function that specifically mentions that it is intended for ISO files or disc images. Do not simply burn the downloaded file as a normal file to the CD. Then the CD will not work.
Windows 7 or higher: You can simply right-click on the file and select "Burn disc image" from the menu.
Older versions of Windows: You can download a free burning software that burns the CD in the correct way from here: https://www.ashampoo.com/en/eur/pin/7110/Brenn_Software/Ashampoo-Burning-Studio-FREE
Using the Rescue System
The rescue CD is bootable. That means that your computer can start directly from this CD. Follow these steps:
Insert the CD into your CD/DVD drive.
Restart your computer.
The next steps can be a little different from system to system.
In some cases the rescue system will automatically start.
In other cases a message like "Press key Enter to boot from CD" might be shown during startup. If that is the case then quickly press the corresponding key on your keyboard. You will only have a couple of seconds to do that before the message vanishes. If you press the key in time then the rescue system will start.
If the rescue system does not start and you do not see any message like the one mentioned above then you need to configure your system manually to start from CD. Unfortunately this can be very different for different kinds of computers. If you do not know how to configure your computer accordingly then we recommend consulting a computer expert.
It might take a while for the rescue system to fully load.
Once the rescue system is fully loaded it will ask you to select your language, country and keyboard type.
After that the rescue system is ready for action. It will look and behave very similar to the restore function in our normal software. You will get on-screen explanations and help for each step directly in the rescue system.
So yeah, Karma!
:) devnullius
19h left!! supereasy 1-click backup for free (TIP! Looks good...)
« Reply #2 on: 12. January 2014., 12:19:51 »
FROM: http://giveaway.download.hr/free-software/supereasy-1-click-backup.html
SuperEasy 1-Click Backup is your simple and convenient solution to backup files incrementally or by version.
The program automatically recognizes your system configuration and connected devices.
Your files are processed as background tasks that do not interrupt your work.
The integrated compression routine achieves a very high compression ratio with minimal storage consumption.
SuperEasy 1-Click Backup Features:
- Complete system backup (image file)
- Recovery disc
- 1-Click setup
- Faster backup routine
- Versioning
- Intelligent pause mechanism
- Backup to network drives
- Backup to locally connected hard disks and USB flash drives
- Backup open files - Selectively restore files and folders
- Fully-automated backups as background tasks
- Pause/continue even after system reboot
- Backup scheduler
- Incremental backups
File compression Product homepage: SuperEasy GmbH & Co. KG: https://www.supereasy.net/en/usd/pin/0021/products/SuperEasy-1-Click-Backup
Supereasy 1-click backup for free v1.13.0_8099 (TIP! Looks good...)
« Reply #4 on: 18. January 2014., 11:57:31 »
