  • Total Topics: 16704
  • Online today: 1854
Guests: 1811
Total: 1813
Author Topic: AOMEI partition assistant 5.5 pro lifetime license (free till Jan 10)  (Read 5808 times)
(thought I already posted it...? Let me know if double post)
FROM: http://geekiest.net/post/AOMEI-Partition-Assistant-Professional-Edition-Lifetime-license-for-FREE.aspx
LEADS TO: http://www.disk-partition.com/specials/softpedia.html
Thanks to Bogdan Popa from Softpedia, we can have the opportunity to giveaway AOMEI Partition Assistant Pro to Softpedia visitors.
Please follow the below steps to get AOMEI Partition Assistant Pro for FREE!
1. FREE Download AOMEI Partition Assistant Pro
2. Enter the Free License Code: AOPR-QP7WC-9V77Y-3UR5M
Valid Date: From Jan 3, 2014 to Jan 10, 2014
Copy Paste Geekiest:
AOMEI Partition Assistant is a well known partition software for windows. It comes in two flavors: Standard (free) and Professional (paid).
AOMEI Partition Assistant has a very simple user interface. It can perform operations ranging from simple (such as resize/move partition, copy partition/disk, merge/split, quickly allocate free space) to complex (such as convert primary to logical and vise versa, hide partition, align partition, Linux partition management, set active partition, convert system disk between MBR and GPT styles and many more).
Following are few important features:
Convert system disk between MBR and GPT styles
Windows To Go Creator, installing Windows 8 to removable flash drive
Migrate system to SSD and support MBR and GPT disk
Create Windows PE bootable media without having to install AIK/WAIK
Completely support hard disk with 4096 bytes sector size
Fully compatible with Windows 8.1
Convert between NTFS and FAT32
One-lick migrate OS to SSD
Fully support UEFI boot
Partition Alignment
Multi-language support
FREE for Commercial Use
Change Partition Type ID
Change Serial Number
Initialize Disk
Rebuild MBR
Support Ext2/Ext3 Linux partition
Partition Recovery Wizard
As you could make it from the above list of features, AOMEI Partition Assistant has every possible disk and partition tool made available to you. Moreover, it support both 32bit and 64bit operating systems from 2000 to latest Windows 8.1.
All-in-all AOMEI Partition Assistant incorporates 30 brilliant functions to help you manage your hard disk. It is a complete solution for your needs and even has an option to create bootable CD for those times when your Operating System fails to boot.
AOMEI in association with Softpedia is brining you a golden opportunity to get a lifetime license of  AOMEI Partition Assistant Professional Edition, which comes with commercial usage. To grab a copy head over to the link below:
PS: this offer is valid up to Jan 10, 2014 and does not provide free upgrades.
MIRROR: https://app.box.com/s/0ftym8xlx28fzbt6wk46
Karma!
Giveaway: AOMEI partition assistant 5.5 pro lifetime license
« Reply #1 on: 15. January 2014., 21:26:13 »
(I will update this thread for future AOMEI Partition tools giveaways - my other two articles are obsolete)
FROM: http://www.mostiwant.com/blog/aomei-partition-assistant-pro-edition-5-0-free-license-key-giveaway/
DOWNLOAD: http://www.aomeisoftware.com/download/giveaway/pa/PAPro3rd5.5.exe (offline? Reply / PM and I'll upload a mirror for this file...!)
KEY: AOPR-008S0-PS6H6-8UXJX
AOMEI Partition Assistant Pro Edition 5.5 Free License Key Giveaway
by william under Disk, Maintenance & Optimization; On December 12, 2013
As we all know, better organization on our hard drive leads to improved speed and reliability. However, some advanced partition management is unavailable with the windows built-in disk partition manager. So third-party partition manager software is still a great need. If you’re looking for an all-in-one software for hard driver management and disk partition, Partition Assistant Professional Edition 5.5 from Aomei Technology is a nice choice.
Aomei Partition Assistant Pro Edition 5.5 is a highly-efficient, easy-to-use and multifunction partition management software, with user friendly operations to assist you mange the partitions of your hard drives. It works similar to the popular Partition Magic application (a famous trademark software of Symantec Corporation) but comes with several advanced tools that can perform more complicated partition operations easily.
With its help, It is easy and reliable to Resize and Move Partition, Repartition Hard Disk, Align Partition, Quick Migrate OS to SSD, Copy Partition/Disk, Fix System/Partition, Convert primary to logical partition and vice versa, Convert disk from MBR to GPT without initialize disk and vice versa, and create bootable CD which could help you launch Partition Assistant in Windows PE in case the current OS crashes. All these changes of partition can be previewed before applying to hard disk and all data is completely protected during all operations and without the risk of data loss (However, we still recommend you first copy and backup your important data to an external hard drive before you operate the partition).  In addition, the new Windows To Go Creator enables you to create a bootable USB drive and allow you to boot Windows 8 or 8.1 from this USB drive. This allows you to save your personalized Windows 8 or 8.1 OS and use it on any compatible device.
Attractive operation is the built-in One-Click Wizard Guides: Disk / Partitio Copy Wizard, Extend Partition Wizard; Migrate OS to SSD or HDD, Partition Recovery Wizard, Make Bootable CD Wizard, and Windows To Go Creator.  With these wizards, you can quickly and easily accomplish your jobs as you expect without losing data. Support running on Windows 8, Windows 7 (SP1 included), Vista, XP, 2000 (both 32bit and 64bit).
AOMEI Partition Assistant Pro Edition supports all the storage devices which can be recognized by Windows, such as IDE, SATA, SCSI, SSD, USB external disks, flash drive, Fire wire disk, Hardware RAID and Flash drive and so on. It is able to support MBR (under 2TB) and GPT (larger than 2TB) with 128 hard disks, with file system FAT, FAT32, NTFS and also EXT2, EXT3.
Support running on Windows 8.1, Windows 8, Windows 7, Vista, XP, and 2000 (both 32bit and 64bit).
Read more about AOMEI Partition Assistant Pro Edition 5.5 : HomePage
AOMEI Partition Assistant Pro Edition normally charges $36 per serial number / license key. But in cooperation with AOMEI Technology, we can offer AOMEI Partition Assistant Pro Edition 5.5 completely FREE to our visitors.
Please firstly download and install AOMEI Partition Assistant Pro 5.5: PAPro3rd5.5.exe [8.3 MB]. And then enter the following code to active full version.
License Code: AOPR-008S0-PS6H6-8UXJX
We are told that you can use the software for a lifetime without functional limitation (Only for current version) but no free upgrades and technical support will be provided for Giveaway Products. We will update you on when this is going to end, so don’t hesitate.
For those who will be missing today’s giveaway, the freeware AOMEI Partition Assistant Standard Edition  (formerly Home Edition) offers pretty much all features the average user would need to manage their disks and partitions.
At last, Thanks Kevin from AOMEI Technology for taking interest in to this blog and arranging the Giveaway for my readers.
Karma!!
