  • Total Topics: 17027
  • Online today: 68623
Guests: 64259
Total: 64259
Author Topic: 12h left!? (sorry, late:) MunSoft Data Recovery Suite 2.0 (TIP)  (Read 2868 times)
(DO take a look at http://scforum.info/index.php/topic,8555.msg22091.html#msg22091 for a LONG list of all truly free data recovery and (some) file repair programs... TIP)
FROM: http://www.nsaneforums.com/topic/202418-giveaway-munsoft-data-recovery-suite-20/
LEADS TO: http://www.giveawayoftheday.com/munsoft-data-recovery-suite-20/
MunSoft Data Recovery Suite has all the data recovery tools you need in order to restore valuable files. It includes 6 data recovery programs, each one of them can be used separately to recover a particular type of file.
The program works with deleted and damaged files of major formats. It incorporates Raw Search, a special technology, created specifically for searching and restoring data even in the most hopeless cases, such as damaged file systems or broken hard drives. Intelligent scan engine locates the files quickly and with as little effort on the user’s side as possible. All you need to do is specify the path and press the launch button. The easiness in use is one of the advantages of the program; it lets everyone from a novice to a seasoned professional use the program equally effectively.
Purchase a personal license (including updates and technical support) at 70% discount :-*
Also see previous giveaways:
- MunSoft Easy Drive Data Recovery http://scforum.info/index.php/topic,8005.msg20133.html#msg20133
- MunSoft Easy Office Recovery http://scforum.info/index.php/topic,8178.msg20800.html#msg20800
And our general article about free full data recovery programs: http://scforum.info/index.php/topic,8555.msg22091.html#msg22091
Karma!
POST-EDIT: F*CK, forgot to install for myself! :( Isohunt.to had " MunSoft Data Recovery Suite 2013 (Activated) Full " for me... Hope it comes close ;p
