banner
banner
  • Total Topics: 13010
  • Online Today: 1355
banner
Author Topic: CPU Mining: Datacoin: February 2014: downloads, pools, miner configuration  (Read 2401 times)
Inspired by: Windows Azure Free CPU Cloud Mining: http://thisweekscoin.com/forum/index.php/topic,948.msg4619.html#msg4619
Datacoin DTC.
Download wallet: http://datacoin.info/index.php?id=index
Download miner: http://azbowling.com/AeroCloud/ *
Download miner software MIRROR Devnullius: https://app.box.com/s/kzuofgl0w8w3osf0r98n
Pool used: http://dtc.candypool.net/ (create account)
%AppData%\Datacoin\datacoin.conf: - (none exists)
Candyminer.bat:
Code: [Select]
candyMiner-T17v12.exe -port 10035 -u devnullius.azure -p yourworkerpassword -t 24I only useed -t 4 cores in my VM, but that did not seem to work well. Using -t 24 fixed that. Before, CPU was not at 100%, 4th core hardly used. Excellent support from candy.pool (@icloud.com), fast replies! I do not know how well they pay. I lack experience. See reply for my earnings...
The .bat file will get you started, but do not forget to add a worker with candypool.net  first. Double-check you are working with DTC, not another currency ;)
Other interesting links for mining Datacoin / Sources:
- https://bitcointalk.org/index.php?topic=384112.msg4132021#msg4132021
- https://bitcointalk.org/index.php?topic=445674.msg4899277#msg4899277
- http://dtc.gpool.net/tutorial
- https://bitcointalk.org/index.php?topic=379601.msg4070070#msg4070070
CPU Only AltCoin List 02/08/2014 Version (UTC)
- https://bitcointalk.org/index.php?topic=380483.0
Most profitable CPU Altcoins to mine (February 2014)
- http://www.reviewoutlaw.com/most-profitable-cpu-coin-list-alt-coin-profits-24-hours-mining/
Karma!
Devnullius
Remarks:
* Make sure you are downloading the Candyminer ( download the one for XPM - it works with dtc too ). Other miners on that page won't work with candypool.
4 cores Azure eval. RAM not important for mining this coin.
Currently it is Feb 14, 2014. As you can see, not many coins mined.
Total number of shares submitted   184
Total DTC recieved   0.02333486683238743
Shares submitted per minute last 24 hours   0.0785
Shares submitted per minute last 7 days   0.0183
Time of last submitted share   2014-02-14 21:05:38
Difficult of last submitted share   6
So Total:   0.0233 DTC, but Unconfirmed:   0.43 DTC. From Support:
"they get confirmed once the block they are in reaches 3200 confirmations.
After that just press instant payout and they should appear in your wallet."
(still nothing for Valentine's Day.... ;-()
2014-02-13 20:05:52   0.0001685136608487558   148014
2014-02-13 20:05:52   0.0001685136608487558   148003
2014-02-13 20:05:52   0.0001685136608487558   147958
2014-02-13 20:05:52   0.0003370273216975116   147940
2014-02-13 20:05:52   0.0001685136608487558   147924
2014-02-13 20:05:52   0.0001685136608487558   147906
2014-02-13 20:05:52   0.0003370273216975116   147886
2014-02-13 20:05:52   0.0001685136608487558   147885
2014-02-13 20:05:52   0.0001685136608487558   147883
2014-02-13 20:05:52   0.0001685136608487558   147873
2014-02-13 20:05:52   0.0001685136608487558   147858
2014-02-13 20:05:52   0.0001685136608487558   147844
2014-02-13 20:05:52   0.0001685136608487558   147838
2014-02-13 20:05:52   0.0003370273216975116   147833
2014-02-13 20:05:51   0.0001685136608487558   147798
2014-02-13 20:05:51   0.0001685136608487558   147789
2014-02-13 20:05:51   0.0033702732169751167   147783
2014-02-13 20:05:51   0.0001685136608487558   147728
2014-02-13 20:05:51   0.0003370273216975116   147717
2014-02-13 20:05:51   0.0001685136608487558   147715
2014-02-13 20:05:51   0.0003370273216975116   147692
2014-02-13 20:05:51   0.0001685136608487558   147658
2014-02-13 20:05:51   0.0003370273216975116   147653
2014-02-13 20:05:51   0.0001685136608487558   147625
2014-02-13 20:05:51   0.0003370273216975116   147622
2014-02-13 20:05:51   0.0001685136608487558   147616
2014-02-13 20:05:51   0.0001685136608487558   147592
2014-02-13 20:05:51   0.0003370273216975116   147533
2014-02-13 20:05:51   0.0001685136608487558   147505
2014-02-13 20:05:51   0.0001685136608487558   147496
2014-02-13 20:05:51   0.0001685136608487558   147490
2014-02-13 20:05:51   0.0003370273216975116   147482
2014-02-13 20:05:51   0.0001685136608487558   147473
2014-02-13 20:05:51   0.0001685136608487558   147468
2014-02-13 20:05:51   0.0001685136608487558   147465
2014-02-13 20:05:51   0.0001685136608487558   147463
2014-02-13 20:05:51   0.0001685136608487558   147428
2014-02-13 20:05:51   0.0001685136608487558   147418
2014-02-13 20:05:51   0.0001685136608487558   147379
2014-02-13 20:05:51   0.0001685136608487558   147366
2014-02-13 20:05:51   0.0003370273216975116   147352
2014-02-13 20:05:51   0.0033702732169751167   147319
2014-02-13 20:05:51   0.0003370273216975116   147291
2014-02-13 20:05:51   0.0001685136608487558   147237
2014-02-13 20:05:51   0.0001685136608487558   147217
2014-02-13 20:05:51   0.0001685136608487558   147195
2014-02-13 20:05:51   0.0003370273216975116   147180
2014-02-13 20:05:51   0.0003370273216975116   147178
2014-02-13 20:05:51   0.0003370273216975116   147175
2014-02-13 20:05:51   0.0001685136608487558   147153
2014-02-13 20:05:51   0.0001685136608487558   147104
2014-02-13 20:05:51   0.0001685136608487558   147100
2014-02-13 20:05:51   0.0001685136608487558   147098
2014-02-13 20:05:51   0.0001685136608487558   147090
2014-02-13 20:05:50   0.0001685136608487558   147047
2014-02-13 20:05:50   0.0001685136608487558   147035
2014-02-13 20:05:50   0.0003370273216975116   147031
2014-02-13 20:05:50   0.0001685136608487558   146977
2014-02-13 20:05:50   0.0001685136608487558   146962
2014-02-13 20:05:50   0.0001685136608487558   146924
2014-02-13 20:05:50   0.0001685136608487558   146907
2014-02-13 20:05:50   0.0001685136608487558   146887
2014-02-13 20:05:50   0.0001685136608487558   146882
2014-02-13 20:05:50   0.0003370273216975116   146877
2014-02-13 20:05:50   0.0001685136608487558   146863
2014-02-13 05:31:09   0.00016408650793606897   134528
2014-02-13 05:31:09   0.00016408650793606897   134517
2014-02-13 05:31:09   0.00016408650793606897   134472
2014-02-13 05:31:09   0.00032817301587213793   134454
2014-02-13 05:31:09   0.00016408650793606897   134438
2014-02-13 05:31:08   0.00016408650793606897   134420
2014-02-13 05:31:08   0.00032817301587213793   134400
2014-02-13 05:31:08   0.00016408650793606897   134399
2014-02-13 05:31:08   0.00016408650793606897   134397
2014-02-13 05:31:08   0.00016408650793606897   134387
2014-02-13 05:31:08   0.00016408650793606897   134372
2014-02-13 05:10:52   0.0001640880840309397   122016
2014-02-13 05:10:52   0.0001640880840309397   122005
2014-02-13 05:10:51   0.0001640880840309397   121960
2014-02-13 05:10:51   0.0003281761680618794   121942
2014-02-13 05:10:51   0.0001640880840309397   121926
2014-02-13 05:10:51   0.0001640880840309397   121908
