banner
banner
  • Total Topics: 13275
  • Online Today: 836
banner
Author Topic: New coin found!! [XSS] Stability Shares - Hyperbolic reward curve  (Read 37697 times)
0 Members and 19 Guests are viewing this topic.
Stability Shares
XSS
Join us at http://webchat.freenode.net/ #stabilityshares !
Our Subreddit - Our Twitter
We've just been added on https://www.cryptoaltex.com/
Currently having a giveaway here!
The standard block halving scheme that bitcoin and a lot of other altcoins use is suppose to represent a hyperbolic curve.
These block halving events have proven to have a lot of speculation occur and therefore destabilizing the market.
Why not let the block reward follow the curve it is trying to represent? We did this, not only to know what the effect is,
but we believe that it is best for the creation of a cryptocurrency to have this.
The following graph shows the blockreward versus the blockheight:
Stability Shares will start with a blockreward of 100 coins and will immediately lower after the first block is mined. Block reward will be under 20 coins when block 200.000 is mined
This will encourage steady and stable increase in the market.
The following graph shows the total supply versus the blockheight:
As you can see the first 200.000 blocks will contain 2/3 of the total amount of coins. This is used to reward early adopters and encourage people to mine the coin rather earlier than later.
The blocks 200.000 till 1.052.200 will contain the rest of the coins and will be mined to supple with increased demand. This is intended to create stability on the market.
Wallets
Windows:
https://mega.co.nz/#!Pt5SCJoY!6VstAAjZulFgj1LuhqVftzsMcxcw05L4_qvCWnBPm78
http://www59.zippyshare.com/v/77317237/file.html
OSX:
Need someone to compile for OSX, message me
Bounty:250XSS + 100XSS from savale
Github source (Will update this later on):
https://github.com/Stygian0708/StabilityShares.git
Latest Source:
https://mega.co.nz/#!X0w0iaaZ!5CvhG6S7kd4HcdbDtAvP5wsGz7IRHuNugS0KUuvWtVo
How to compile for linux:
chmod +x the build files
run make -f makefile.unix
Technical specifications
-Algorithm: Scrypt Proof of Work
-Total amount of coins: Just under 15,000,000 XSS (Hardcapped in the code at 15,000,000 XSS)
-Premine: 0,2% or 30,000 XSS for development of this coin (bounties etc.)
-Block time: 90 seconds or 1.5 minutes
-Total amount of blocks: 1,052,200, this will amount to 3 years
-The first 100 blocks will have a lower reward of 10 coins per block, for starting the network fairly and prevent instamining
-Starting blockreward: 100 XSS
-Ending Blockreward: ~2.2 XSS
-Transaction confirmation time: 6 blocks or ~9 minutes
-Block maturity time: 100 blocks or ~2 hours
-Using Kimoto's Gravity Well for difficulty readjustment
Ports
Main Net:
Peer 2 peer port: 7711
RPC port: 7712
Test Net
Peer 2 peer port: 17711
RPC port: 17712
Pools
http://xss.cryptopirates.net/
http://xss.morecoins.org/ (reported to have problems, will keep an eye on situation)
http://xss.okaypool.com/
http://coin-base.info/stabilityshares/
http://xss.coins-pool.com/ (EUROPE, 0.5% fee)
http://xss.scryptominers.com/
http://xss.thelanhouse.net
http://xss.thomo.vn/
http://xss.charityminingpools.com/
http://61.160.82.172:8002/ (CHINA)
P2P Pool
http://137.116.245.160:7777/static/
stratum+tcp://137.116.245.160:7777
USER: your_wallet_address
PASS: 123
Block Crawler:
http://coin-base.info/xss_blockcrawler/
Exchanges
500 XSS reward for exchanges!
No connection/No syncing? Read here below.
As the stabilityshares executables have nog dns seeder inserted node have to be added for manual connection.
How to add these nodes?
First start your client, let it load up and close it.
Go to your appdata/roaming/stabilityshares folder.
Make a new file called stabilityshares.conf and past the following code into it
Code: [Select]
listen=1
daemon=1
server=1
rpcuser=xssuser
rpcpassword=stability123
rpcport=7712
port=7711
addnode=80.112.144.84
addnode=82.139.127.205
addnode=23.253.82.83
addnode=27.33.1.58
addnode=87.147.43.53
addnode=174.108.122.202
addnode=204.195.130.236
addnode=92.55.41.212
addnode=88.127.170.75
Now save and close the file. Start up the client and if all is well, it should sync and connect.
GIVEAWAY? Go here: http://thisweekscoin.com/forum/index.php/topic,1121.0.html
Devnullius
Convenient links to help you trading and ways to *donate* me: http://thisweekscoin.com/forum/index.php/topic,3.0.html
New exchange with free coins for just creating a free account. Includes referral system too. https://comkort.com/?r=973966
Open giveaways I'm hosting with generous support from miners & ThisWeeksCoin:
- My BEST giveaway is this: http://qoinpro.com/d0fd8e9b995ad58bc444a181cd0175fa
- Star Trek Fancoins (with exchange): KED, UFC, GPL? Go to http://thisweekscoin.com/forum/index.php/topic,1069.0.html
- KED Klingon Empire Coin https://twitter.com/devnullius/status/437320749322608641
- UFC United Federation of Planets Credit System https://twitter.com/devnullius/status/437043021562269696
- GPL Gold Pressed Latinum https://twitter.com/devnullius/status/437610758478630912
- PTR: Petrodollar: http://scforum.info/index.php/topic,8850.0.html
- POT coin: http://coinzen.org/index.php/topic,303.0.html
- POT Aléén voor Nederlandstaligen!! http://thisweekscoin.com/forum/index.php/topic,827.msg2370.html#msg2370
Coins I really like: #potcoin #lottocoin #takeicoin #fastcoin #datacoin #scificryptocoin #antimatter #petro$ #litebar #huntercoin #zeitcoin #aurora
Coins I am interested in: #heavycoin #mintcoin #leafcoin #electric #grumpycoin #corkiecoin #battlecoin #fckbanks #marinecoin #H2O
Coins that seem fun: #maxcoin #flappycoin #cagecoin #stackcoin relaunch #rabbitcoin #beecoin
Coins I'm regretting: #panda (new) #selling panda (old) #stackcoin scam #UNO #Globalcoin
SCForum's Software Grab 'n' Snatch!!! http://scforum.info/index.php/topic,8638.0.html
