SHERLOCK COIN (SHC) - The Game is on to the Crypto World!
Now With
Kimoto Gravity Well Implemented (KIMOTO GRAVITY WELL © Courtesy of inventing Dr. Kimoto!)
Fast Transaction Confirmations (3 Confirmations)
30 Confirmations for Mined Blocks
A MADATORY CLIENT UPDATE
SherlockCoin Wallet Updated to 1.2.2 to Fix Heartbleed Openssl Security Vulnerability
“A bug in OpenSSL, used by SherlockCoin-Qt/Sherlockcoin Core , could allow your watsons to be stolen. Immediately updating SherlockCoin Core to 1.2.2 is Mandatory."
http://www.mediafire.com/download/yb1hv654t8hg8bl/Sherlockcoin_1.2.2_Windows_Wallet.zip
- KGW TW FIX POSTED
- CHECKPOINTED
- HARDFORK AT 25600 PLEASE UPDATE ASAP
*PLEASE BACKUP YOUR WALLETS BEFORE ATTEMPTING ANYTHING*Copy your wallet.dat at (%APPDATA%/BeeCoin to a safe location)OverviewSHERLOCK COIN [SHC] - The Game is on in the Crypto World!
Sherlock Holmes, as you may know is the best detective and genius of all time. As a tribute to the great works of Sir Arthur Conan Doyle and to the man himself, Mr Holmes. This coin is solely based on character of Sherlock Holmes and the ingenuity shown whilst solving mysteries, the same ingenuity can be seen in this coin. I am dedicating this coin to all the enthusiasts of Sherlock Holmes, I believe and have faith that this coin will make it through and will be a success, This will be something to hold on to and cherish. (Proof Read , Courtesy of Ratters)
As you probably know by now that the board get's spammed uncontrollably by ALT-Coins releases everyday , some might survive some might not I want SHC to be treasured not at all a pump and dump coin but a coin to cherish the name of Sherlock Holmes and for the enthusiasts to treasure it and if you want to spread it around.
LaunchThis is a fork of Litecoin and developed using foundations and guidance documented by beloved members here who have committed and pledged their support for cryptocurrencies mainly Bitcoin as well as Alt-coins , my salute is to all who strive to make Cryptocurrencies the future and the dedication of developers who work night and day to make that dream a success , this coin is not a competitor to Bitcoin nor other ALT coins but a strength to the world of Cryptocurrencies and my contribution thus stands and will always with the community , we should never forget the past , thus as they say if done will be void of a future , therefore my salute goes to Bitcoin , it's founders and developers and the community that stands by it and everyone on this forum , thereby paying my respect as we all know we should be thankful of Bitcoin without it we would never would have imagined or known about a world of Cryptocurrencies.
Salute! Please Note: This is NOT a paid up over the counter/website coin , that just popped out of a script on a website after making a Bitcoin Payment , I had to put my sweat , tears , dedication , sacrifice and time (lot's of it) , had to put 200% of my effort, trial and error , learning , failures to make this workout , this coin opened up a new chapter in my life , learning , as I've learned alot while making this , I kindly ask you to respect that while criticizing if you may require. (Proof Read , Courtesy of Ratters)
BOUNTIES & GIVEAWAYSSherlockCoin(SHC) First Giveaway! coins to the first lucky 221 people!http://www.reddit.com/r/SherlockCoin/comments/1xcczl/sherlockcoinshc_first_giveaway_coins_to_the_first/
MINER MARATHON CONTEST SHERLOCK COIN (SHC)
https://bitcointalk.org/index.php?topic=458195.0
[MYSTERY SOLVER CONTEST] SHERLOCK COIN (SHC) + | only 221 coins to be mined | +
https://bitcointalk.org/index.php?topic=456389
[2 in 1] VOTE AND WIN GIVEAWAY! 2nd Giveaway! How to get Sherlockcoins?
https://bitcointalk.org/index.php?topic=461273
FAUCET
http://earncryptocoins.com/shc
WEBSITE
http://www.sherlockcoin.org/ (Under Maintenance)
BLOCK EXPLORER
http://cryptexplorer.com/chain/SherlockCoin (courtesy of candidakefyr thank you very much mate)
FORUM
To Be Announced
SPECIFICATIONS
Scrypt
221 coins Max
221 second block time
Kimoto Gravity Well Implemented (KIMOTO GRAVITY WELL (c) Courtesy of inventing Dr. Kimoto!)
Difficulty re-target every 10 minutes
0.00000010 Block reward for the first 221 blocks (Conveniently set to allow you to get your miners running)
Blocks 221+ are 0.0000221 block reward
Random Block Rewards/Super Blocks!
Block 212 is a Special Block with More Rewards than the normal block value (0.000221 Coins)
Tx fees are 0.00000001
RPC port 55883
p2p port 55884
0.1% (0.221 coins) Premine for Testing/Bounty and Giveaway Purposes.
RANDOM BLOCK REWARDS INFO
At Block 2 Reward = 0.000221
At Block 21 Reward = 0.000221
At Block 42 Reward = 0.000221
At Block 122 Reward = 0.00221
At Block 144 Reward = 0.000221
At Block 166 Reward = 0.00221
At Block 188 Reward = 0.000221
At Block 199 Reward = 0.00221
At Block 202 Reward = 0.000221
At Block 212 Reward = 0.000221
At Block 221 Reward = 0.00221
At Block 242 Reward = 0.000221
At Block 284 Reward = 0.00221
At Block 302 Reward = 0.000221
At Block 312 Reward = 0.00221
At Block 322 Reward = 0.000221
Updates to Follow
DOWNLOADS
Source Code UPDATED
https://github.com/sherlockcoin/sherlockcoin
Change Log:
v1.2.2
- Fixed KGW TW Hardfork at Block 25600
- Checkpointed
- Addressed Openssl HeartBleed Security Vulnerability
- Version Bumped to 1.2.2 from 1.2.1
- KGW TW FIX POSTED
- CHECKPOINTED
Windows Wallet Version 1.2.2 http://www.mediafire.com/download/yb1hv654t8hg8bl/Sherlockcoin_1.2.2_Windows_Wallet.zipLinux Wallet Version 1.2.2http://www.mediafire.com/download/6yae5o2d5y4hxxq/Sherlockcoin_1.2.2_Linux_Wallet.zipMac Wallet Version 1.2.2Sample sherlockcoin.conf file:rpcuser=username
rpcpassword=password
rpcallowip=127.0.0.1
rpcport=55883
port=55884
listen=1
daemon=1
server=1
addnode=sherlockcoin.no-ip.biz
addnode=seednode1.sherlockcoin.org
For Windows%appdata%/SherlockCoin/sherlockcoin.conf
For OS X it should be:~/Library/Application Support/SherlockCoin/sherlockcoin.conf
For Linux it should be in:~/.sherlockcoin/sherlockcoin.conf
POOLShttp://shc.bondni.com (Our First Pool! Thank you very much to our beloved user temple)
http://pools.animusgs.co.in/shc/ (Thanks to aizzaku & anush3070)
http://shc.altcoinpool.org/ ( Thanks to nbphuoc)
EXCHANGEShttps://www.bittrex.com/Market/Index?MarketName=LTC-SHChttps://www.bittrex.com/Market/Index?MarketName=BTC-SHChttps://www.allcrypt.com/market?id=639https://xnigma.com/markets/view/48http://www.lazycoins.com/ (Featuring SHC at Premier Launch courtesy of the respected Developers at LazyCoin)
SERVICES / OTHER[ANN] First Shop to Accept Sherlockcoins!Memorabilia!#IAMSHERLOCKEDhttps://bitcointalk.org/index.php?topic=531000SOCIALTWITTERhttps://twitter.com/SherlockCoinFACEBOOKhttps://www.facebook.com/sherlock.coinREDDIThttp://www.reddit.com/r/SherlockCoin/ IRC FreeNodeTo be Announced
NEWShttp://bitbillions.net/2014/02/28/alt-currencies-introducing-sherlock-coin/THREADS[ANN]SHERLOCK COIN (SHC)|NOW TRADED ON BITTREX.COM+|only 221 coins to be mined +
https://bitcointalk.org/index.php?topic=454981
SherlockCoin(SHC) First Giveaway! Coins to the first lucky 221 people!
https://bitcointalk.org/index.php?topic=456232
[LAST TO POST CONTEST] SHERLOCK COIN (SHC) + | only 221 coins to be mined | +
https://bitcointalk.org/index.php?topic=459926
[BUY/SELL] SHERLOCK COIN (SHC) + | only 221 coins to be mined | +
https://bitcointalk.org/index.php?topic=459667
[VOTE] TO GET SHERLOCK COIN (SHC) ON AN EXCHANGE +|only 221 coins to be mined +
https://bitcointalk.org/index.php?topic=459503
[MINER MARATHON CONTEST] SHERLOCK COIN (SHC) + | only 221 coins to be mined | +
[2 in 1] VOTE AND WIN GIVEAWAY! 2nd Giveaway! :) How to get Sherlockcoins? :P
[VOTE]SHERLOCK COIN (SHC)|Lowest Denomination Suggestions! :)
https://bitcointalk.org/index.php?topic=487047
[SHERLOCKCOIN] TWEET UP! AND RECIEVE 0.0000221 Watsons PER POST! :)
https://bitcointalk.org/index.php?topic=495512
[QUICK] SherlockCoin Giveaway (0.00000221 SHCs) Per USER! Just Tweet! :)
https://bitcointalk.org/index.php?topic=490608
[MYSTERY SOLVER CONTEST 2 ]SHERLOCK COIN (SHC) + |only 221 coins to be mined | +
https://bitcointalk.org/index.php?topic=489904
[VOTE] SherlockCoin to get on CryptoRush Giveaway (221 Watsons) Per USER!
https://bitcointalk.org/index.php?topic=508878
Unknown and Mysterious coin , standing strong amidst all Perfect to invest in!
https://bitcointalk.org/index.php?topic=529890
[TO THE MOON] SHERLOCKCOIN TRADING AT OVER 80 BTC on BITTREX! :)
https://bitcointalk.org/index.php?topic=529929
https://bitcointalk.org/index.php?topic=547785.0
For more services it's best to check out the website links at the top of this information thread.
Elementary my dear alt-coiner!
These coins will be rare!
