  • Total Topics: 16537
  • Online today: 2794
Guests: 2642
Total: 2644
Author Topic: High-temperature superconducting secrets solved after 30 years | Amazing Science  (Read 2231 times)
http://tldr.scoop.it/geek-love/p/4023121420/2014/06/17/high-temperature-superconducting-secrets-solved-after-30-years
 High-temperature superconducting secrets solved after 30 years | Amazing Science | Scoop.it
From phys.org -    June 18, 2:21 AM
A breakthrough has been made in identifying the origin of superconductivity in high-temperature superconductors, which has puzzled researchers for the past three decades.
Harnessing the enormous technological potential of high-temperature superconductors – which could be used in lossless electrical grids, next-generation supercomputers and levitating trains – could be much more straightforward in future, as the origin of superconductivity in these materials has finally been identified.
Researchers from the University of Cambridge have found that ripples of electrons, known as charge density waves or charge order, create twisted 'pockets' of electrons in these materials, from which superconductivity emerges. The results are published in the June 15th issue of the journal Nature.
Low-temperature, or conventional, superconductors were first identified in the early 20th century, but they need to be cooled close to absolute zero (zero degrees on the Kelvin scale, or -273 degrees Celsius) before they start to display superconductivity. So-called high-temperature superconductors however, can display the same properties at temperatures up to 138 Kelvin (-135 degrees Celsius), making them much more suitable for practical applications.
Key to conventional superconductors are the interactions of electrons with the lattice structure of the material. These interactions generate a type of 'glue' which holds the electrons together. The strength of the glue is directly related to the strength of the superconductor, and when the superconductor is exposed to an increase in temperature or magnetic field strength, the glue is weakened, the electron pairs break apart and superconductivity is lost.
"One of the problems with high-temperature superconductors is that we don't know how to find new ones, because we don't actually know what the ingredients are that are responsible for creating high-temperature superconductivity in the first place," said Dr Suchitra Sebastian of the Cavendish Laboratory, lead author of the paper. "We know there's some sort of glue which causes the electrons to pair up, but we don't know what that glue is."
In order to decode what makes high-temperature superconductors tick, the researchers worked backwards: by determining what properties the materials have in their normal, non-superconducting state, they might be able to figure out what was causing superconductivity.
Previous attempts to determine the origins of superconductivity by determining the normal state have used temperature instead of magnetic field to break the electron pairs apart, which has led to inconclusive results.
As cuprates are such good superconductors, it took the strongest magnetic fields in the world – 100 Tesla, or roughly one million times stronger than the Earth's magnetic field – in order to suppress their superconducting properties.
These experiments were finally able to solve the mystery surrounding the origin of pockets of electrons in the normal state that pair to create superconductivity. It was previously widely held that electron pockets were located in the region of strongest superconductivity. Instead, the present experiments using strong magnetic fields revealed a peculiar undulating twisted pocket geometry -similar to Jenga bricks where each layer goes in a different direction to the one above or beneath it.
These results pinpointed the pocket locations to be where superconductivity is weakest, and their origin to be ripples of electrons known as charge density waves, or charge order. It is this normal state that is overridden to yield superconductivity in the family of cuprate superconductors studied.
