  • Total Topics: 16532
  • Online today: 3056
Guests: 2855
Total: 2858
Author Topic: Mcafee 8.7i Required hot fix for eng5700 update  (Read 58375 times)
Re: Mcafee 8.7i Required hot fix for eng5700 update
« Reply #30 on: 02. December 2014., 21:51:07 »
As for 5600 Engine, you can get it by applying a SuperDAT, or just updating McAfee the normal way
Patsheart
« Reply #31 on: 26. December 2014., 16:17:32 »
Patch 5 Password needed.
FaceBook ID: Patrick Reed
« Reply #32 on: 26. December 2014., 20:30:42 »
This is not the topic for that
Laurik
« Reply #33 on: 20. March 2015., 08:58:14 »
Hey guys!
Anybody got Hotfix 982564 yet? Have you tried to update VSE through normal way, and reach engine 5700? Any hope?
Thx.
« Reply #34 on: 22. March 2015., 11:39:58 »
Hey guys!
Hi L.
As I see, no one doesn't have this Hotfix yet... however, my VSE 8.8 (I just checked) now use Scan Engine v. 5700.7163.
Obviously, it's updated automatically through regular updates. ;)
Laurik
« Reply #35 on: 08. April 2015., 12:40:58 »
Thanks!
However i have tried to autoupdate the Mcafee 8.7i, and the engine is not autoupdated to 5700, only virus definitions. The message is that the product have ended his lifecycle.(because of missing hotfix).
But there is a solution for those who not want to go to version 8.8, please see my post on page 2, using the mcafee community super dat  Sdat5700.exe release candidate who not require that the Hotfix 982564 to be installed separately.
https://community.mcafee.com/message/347137
I have instaled SDat5700Eng.exe from previous link and my engine is now 5700.7163. As far as i know the release candidate is close to final version. And as i see is working!  :bih:
Also the following scenario is possible(not tested):
-hotfix installed by previous SDat5700Eng.exe release canditate;
-you can install files mannualy for actual 5700 engine by replacing procedure described by mcafee in engine instructions;
Hope this will help.
« Reply #36 on: 11. April 2015., 09:34:33 »
Nice little trick... :thumbsup:
That is the real strength of SCF Community - Sharing!
Thanks pal,
moezoe
« Reply #37 on: 05. June 2015., 13:24:00 »
hy all.. im sorry late to post..
i have success update to 5700.. before, i have engine 5400. i try to pacth with [i don't know detail of the pacth] but its work.. and the mcafee work great ..
this my screenshoot..
from my internet cafe server..
if you want the pacth.. i'll send to samker or other moderator..
and i'll follow rule this forum to share.. :D  :up:
Just For Fun With Multiple Operating System, check at http://scforum.info/index.php/topic,8046.0.html
Overclocking Intel E7500 Core2Duo, Check at http://scforum.info/index.php/topic,8047.0.html
Overclocking Intel E5400 Dualcore @2.7 GHz Up to @4.0 GHz, check this..!! http://scforum.info/index.php/topic,8045.0.html
« Reply #38 on: 06. June 2015., 11:28:22 »
Hi M. and thanks for feedback. :thumbsup:
Right now, I'm not sure did you update your AV engine with using Laurik's trick (above) or you have Hotfix 982564 (VSE870HF982564.zip) for McAfee 8.7i ??
If you have mentioned Hotfix, please upload it somewhere and post download link in to your next reply. ;)
cya later,
moezoe
« Reply #39 on: 15. July 2015., 07:47:47 »
yes.. this is Hotfix 982564 in the exe name of the zip..
i'm not remember the source.. but still save the file..
i save in google drive..
sorry for my mistake.. :)
Code: [Select]
https://drive.google.com/file/d/0B79q4q8AjQfQT1ZfZWlRb3JyMkE/view?usp=sharing
