179 (7) mmcblk0p7 1044/1164 MB p7, ext4, /data (89%)
The drawback will be that for the apps moved to the external partition, the overall performance of the phone will be degraded and will be dependant of the SD card bus speed.
Mine have the Newman-K2SV.1.0.4 and i upgrade to Newman-K2SV.2.0.1 (Flash) the only way due to the fixed system partitions.First you have to backup de IMEI (...), because you will lose it with the SELECTED FORMAT ALL IN+DOWNLOAD FLASHTOOLS, ALL SELECTED, included Preload.I Root the phone first, used Mobileuncle MTK and BACKUP IMEI to SDCARD.
- Select a the MT6592_Android_scatter_emmc.txt in ROM- Wait file to be added into Flash Tool- choose Option -> USB Model, click USB Model –> Choose Option -> DA DownLoad All -> Speed -> High Speed, click High Speed- in main screen of Flash tool, select: "Format all + download"- Turn off your phone, remove the battery.
- hit Download button (...) (in Flashtool)- and connect your phone into the computer via USB data cable.- The process will start and a red progress bar will appear after color purple, yellow.- And green circles display- Finish !
That's why they told you to backup the IMEI... I hope you have the box arround, It should be noted there (or in a sticker where the battery goes).You'll have yo find the IMEI-related file and do some HEX edit. The IMEI is not bound to the SIM, but to the device. Think of it as the Device Unique Registration Number, where as the SIM refers to your mobile carrier, number, plan, etc.I know in odin that you can edit the pit file and alter the partition table that way, here... I don't know to be frank. It should be possible, you can try using console tools from Android terminal when rooted I believe.
