  • Total Topics: 16533
  • Online today: 3188
Guests: 3187
Total: 3188
Author Topic: HELP: Newman telephone: insufficient storage available (android): Fixed  (Read 30370 times)
You could put a script in init.d that remounts /data to that partition, but you'll lose the ability to save music and files in the emulated internal SD card.
That would work :)  How to set it up? And plenty ofntools to read linux partitions with windows, so I could atill do music, no? :)
I'm not quite sure.. but There's a possibility.
As for the script, you should only need to drop it in /etc/init.d/
It should say something like
unmount /data
mount /dev/mmcblk0pX /data -t ext4... (exact sintax here may differ)
If your kernel doesn't support init.d scripts, you migth try using a install-recovery.sh script, wich is the work-around for samsung stock kernels for example.
unmount /data
What happens with original /data...? Isn't that needed too?
original /data just won't be used. Before applying this trick you migth want to copy the contents of /data to the new partition.
Dorge1957
You can choose where you want to install your app in phone memory or in SD card and you can change it from phone setting.
http://www.china-prices.com/phone/621/newman-k2s
