0 Members and 10 Guests are viewing this topic.
OK here again, do you want to do the setup right now?if so can use the public/real IP on a LAN card right now?if so add me on your skype by the same user name i am using on here. so you can give me team viewer information to log in your system.
The feature is called port triggering :pBasically, outgoing traffic in one port triggers port forwarding in a set of ports...
Quote from: metalmunna on 12. November 2014., 02:23:54OK here again, do you want to do the setup right now?if so can use the public/real IP on a LAN card right now?if so add me on your skype by the same user name i am using on here. so you can give me team viewer information to log in your system.Again, I wanna set it up right the first time... Not gonna do it tonight, bed soon! I'll prepare as much as I can. But no WAN for server...
Sooooo... we finally configured her VMs..As for the windows boxes, there was not much to do, just map some random non-standard port in her router to the corresponding port in the VM, also we made sure the VMs had all static IPs..As for the Ubuntu 14.04 VM, things got funny, as it results that xRDP doesn't work wiith it out-of-the-box.After some googling, we had to install xfce4 desktop in the VM, and tell xRDP to use xfce4 for its connections by appending xfce4-session to .xsession file in the user's home directory. We added the file to /etc/skel too so any new user would get the configuration right without extra work.Tricky part was that Ubuntu wan't accepting external connections (from outside the LAN), so we had to take a look to ufw too, after some hours eveything got working and now Devvie is happy :p
