you will have to get the appropriate “lp.cab”, i.e. from the Language Pack DVD. Then, type this in a command prompt as Administrator (change path and language code appropriately):dism /online /add-package /packagepath:D:\langpacks\en-us\lp.cabbcdedit /set {current} locale en-USbcdboot %WinDir% /l en-USAfter that, remove the registry folder HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\MUI\UILanguages\de-DE.RebootIf you get this error: An error occured trying to open d:\en-us\langpacks\lp.cab Error:0×80070003. The System cannot find the path specifiedcopy the lp.cab to C:\ (the root directory) and run dism from there.The command line shell must be run as Administrator.
