  • Total Topics: 17012
  • Online today: 22350
Guests: 22166
Total: 22169
Author Topic: Firefox crashing a couple of times a day  (Read 8369 times)
Papilio
« on: 20. December 2014., 22:56:57 »
Hi there,
since a few weeks, my firefox is crashing a couple of times a day..
Now, that i've seen the same with my sisters firefox, on her PC and with my parents', i thought it might not be a problem with my firefox (the plugins i'm using).
Do you, if you use it, experience the same?
Is the current version might just not stable?!
Thanks!
Best regards.
Re: Firefox crashing a couple of times a day
« Reply #1 on: 21. December 2014., 00:38:50 »
Hi there,
Thanks!
Best regards.
First thing: clear browser cache.
Still problem? first thing to do is a full system hard disk check (check for bad sectors too). Install Acronis Drive monitor to check if you are having harddrive problems. Repost results :)
« Reply #2 on: 21. December 2014., 01:11:51 »
I would start by having a look at your installed add-ons and plugins :p
« Reply #3 on: 21. December 2014., 09:59:20 »
Also, provide us more information about your OS and which FF version you use? Is it same on all Computers?
Do you get some error code?
cya later,
taopik
« Reply #4 on: 22. December 2014., 19:55:26 »
Hi there,
Thanks!
Best regards.
my suggest is delete all add on was installed and if there is problem u can clean your memory manually ...
i have some issue like that and solved with that
A41202813GMAIL
  • XPOCALYPSE FOREVER !
FF.
« Reply #5 on: 23. December 2014., 10:56:34 »
The Only Bug I Find In FF34 - The Tabs Last Used Are Ignored In Favor Of The Home Page, When The Browser Starts.
Cheers.
A41202813GMAIL
FF.
« Reply #6 on: 10. November 2015., 03:08:41 »
When A Browser Has Problems:
A1 - Restart The Browser,
A2 - Test The Browser, Again.
B1 - Disable All Extensions,
B2 - GoTo ( A1 ).
Cheers.
myphonecarduk
« Reply #7 on: 14. October 2016., 17:45:36 »
The best solution that I can say is reinstalling your windows, If you don't want to do that install Advanced Uninstaller Pro and then do a complete reinstall, then install a latest version. Also scan your full PC with Avast Anti virus and clean everything, Finally clean all with CC cleaner and start up new. Hope your problems will be resolved.
Melisa
« Reply #8 on: 17. January 2018., 09:36:33 »
Thanks admin, much appreciated.
