Yeah it's me again, from opposites world
I think I messed up my server with that free ashampoo tool the other day
sfc is ok . Removing devices & installing again doesn't work. Still to test: install intel network software instead of default Microsoft device drivers.
Problem: I suddenly couldn't connect to my Windows Server 2012 R2 any longer. I couldn't figured it out, all looked good and I was using a static IP address. Only after I set the IP to DHCP I found out why I wasn't connecting. A simple ping confirmed: though the server can access the internet (so IP should be ok), the IP address is not ok.
When set to DHCP, the IP address changes to the 169 private subnet. So somehow, somewhere, Ashampoo 'locked' my IP settings. Also interesting: when I removed the LAN devices (set to static IP), the static IP address would be remembered once the device was installed again. It should jump to DHCP as far as I can tell :s But not this time
I used TCP Optimizer (
http://www.speedguide.net/downloads.php), to no aveil. Regwarrior's Windows Repair All in One wouldn't properly work in normal mode, so I've rebooted to safe mode with network. WR-AIO is now running but I'm afraid of the results... This is just so #$*(%$*(% strange. I'm open to suggestions - I don't want to re-install server again!
why can I connect to internet with 169.254 IP address? Why doesn't it receive a valid 192 subnet address??
