  • Total Topics: 16673
  • Online today: 4163
Guests: 1643
Total: 1644
Author Topic: LOTUS NOTES MAILMAN ERROR  (Read 14635 times)
0 Members and 10 Guests are viewing this topic.
frescoabeyta
« on: 23. October 2015., 19:54:20 »
When i try to send a document with send email from ms word, lotus notes does'nt open and i have an error message
All help would be appreciated.
Re: how to resolve Lotus Notes MailMan error
« Reply #1 on: 25. October 2015., 18:28:05 »
Hi F. and Welcome to SCF Community.
I would like to know do you get any additional message like "Invalid Pointer", "Notes Error - Cannot locate Default Form" or anything else?
Until you provide us additional information, here you have instructions how to resolve the most common errors in Lotus Notes:
- Lotus Notes MailMan Error: Invalid Pointer: http://www-01.ibm.com/support/docview.wss?uid=swg21605239
- Lotus Notes MailMan Error: When using file...: http://www-01.ibm.com/support/docview.wss?uid=swg1LO40570
- Lotus Notes MailMan Error: Notes Error - Cannot locate Default Form: http://www-01.ibm.com/support/docview.wss?uid=swg21459434
cya later,
SykesSykes
Re: LOTUS NOTES MAILMAN ERROR
« Reply #2 on: 26. October 2015., 13:49:22 »
Hi,
Here is the solution that works.
The installation parameters is essential to get the Notes installation working. In this case of "Mailman error" the solution is to put citrix=1 in the end of the installations options.
Our installation look like this:
chgusr /install
msiexec /i "\\dkccm001\packagesource$\LotusNotes851\SP0\Lotus Notes 8.5.1.msi" TRANSFORMS="\\dkccm001\packagesource$\LotusNotes851\SP0\Lotus Notes 8.5.1.mst" /qr+ SETMULTIUSER=1 MULTIUSERBASEDIR="C:\Documents and Settings\!UserName!\Application Data" MULTIUSERCOMMONDIR="C:\Documents and Settings\All Users\Application Data" CITRIX=1
"\\dkccm001\packagesource$\LotusNotes851_FIX\SP0\LotusNotes851_FIX3\lotus_notes851FP3_basic_win.exe" /NOUSER
copy \\dkwds001\software$\Citrix\Software\Notes_851\notesconfig.txt "C:\Documents and Settings\All Users\Application Data\Lotus\Notes\Data" /Y
chgusr /execute
The file notesconfig.txt contains this:
Domino.Name=dknts001
Username=%UserName%
KeyFilename=C:\Documents and Settings\%UserName%\Application Data\Lotus\Notes\Data\%UserName%.id
Directory=C:\Documents and Settings\%UserName%\Application Data\Lotus\Notes\Data
The trick with notesconfig.txt help to setup new users that have no notes.ini jet, so there is only the Notes password to enter for new users.
I have put some more information into this post and I hope this also can help other to get a better Notes installation than you can get from IBM web site or the default installation. If you are still experiencing the issue I can suggest this program Recovery Toolbox for Lotus Notes
https://recoverytoolbox.com/lotusnotes.html
frescoabeyta
« Reply #3 on: 27. October 2015., 13:35:21 »
Thanks everyone ;)
mariasclarks
« Reply #4 on: 04. November 2015., 06:13:00 »
Use some "NSF to PST Converter" software  to convert all IBM Lotus Notes to MS Outlook program or migrate your NSF file to PST file format. This software saves converted mail items folders as PST, MSG, or EML files.
Chandrabhan02
« Reply #5 on: 04. June 2021., 06:10:35 »
Hi! You can try an advanced DRS NSF to PST Converter tool free that can best way to convert lotus notes to outlook PST format. Using this tool you can get the best results. Dear after downloading this software you have to free version of this software. It is a more reliable and perfect tool.
https://www.data-recovery-solutions.com/nsf-to-pst-converter.php
paulneri370
« Reply #6 on: 12. April 2023., 11:28:54 »
I am employed in Regain Software and working on NSF to PST Converter tool. It helps user to transfer mailbox from Lotus notes to outlook pst file. It also available with free version.
https://www.regainsoftware.com/nsf-to-pst-converter.html
