  • Total Topics: 16942
  • Online today: 137698
Guests: 132290
Total: 132291
Author Topic: (solved) windows 10 shutdown /s /t 5 works, normal shutdown doesn't work & fails  (Read 5076 times)
As described; instead of shutting down windows would turn back on again (without ever going completely off) and it appears like you just logged in again (some programs disappear, others are started).
Solution: http://www.askvg.com/fix-windows-8-restart-and-shutdown-problems-by-disabling-hybrid-shutdown-feature/
Copy paste below; see original article for screenshots and more info
First of all you'll need to open Power Options window which can be opened using any of following methods:
a. Press WIN+R keys together to launch RUN dialog box and then type powercfg.cpl and press Enter.
b. Press WIN+X keys together to launch "WIN+X Menu" and then select "Power Options" from the list.
c. If you are on new Start Screen, type power and Windows will automatically search for the term and will show you the results. If you are on Desktop, move your cursor to top-right corner of screen to access new Charms Bar. Now click on Search option and type power in search box. Now click on Settings link given in right-sidebar of search results page and then click on "Change what the power buttons do" link given in the search results.
STEP 2:
In Power Options window, click on the "Choose what the power buttons do" link given in left sidebar.
STEP 3:
Now scroll down to bottom and you'll see "Turn on fast startup (recommended)" option given in Shutdown settings section.
STEP 4:
Disable the option by unchecking the checkbox and then click on "Save Changes" button.
PS: If the option is not shown or greyed out, scroll up and click on "Change settings that are currently unavailable" link. It'll allow you to change the option settings.
STEP 5:
That's it. Restart your system and your reboot or shutdown problems should get fixed in Windows 8 and later.
NOTE: If the above solution doesn't fix your problem, you can try to execute following command in Command Prompt. Open Command Prompt as Administrator by right-click on the bottom-left corner and select the same option from the Win+X menu:
bcdedit /set disabledynamictick yes
The above mentioned command used to fix a very annoying freezing issue found in Windows 8 Release Preview build. According to Microsoft the issue was fixed in Windows 8 RTM but if you are still facing the issue, you can try the command.
Peace!
Devnullius
