  • Total Topics: 16999
  • Online today: 23577
Guests: 20735
Total: 20735
Author Topic: How to Remove DRM from Apple Music?  (Read 7807 times)
victorhan2012
« on: 31. July 2017., 09:01:14 »
Apple music is protected by FairPlay DRM so that you cannot listen to the music you subscribed on any devices that aren’t linked to your Apple music account. So if you want to play the Apple music on your device that doesn’t have Apple music application, you have to find a way to remove the DRM protection on Apple music. DVDFab DRM Removal for Apple is an excellent Apple music DRM removal tool which can remove DRM from Apple music files easily. Now please follow me to have a look.
Note: Before using DVDFab DRM Removal for Apple, you need to allow iTunes to “share iTunes library XML with other applications”. Please run iTunes, navigate to Edit > Preferences > Advanced, and check the box before “Share iTunes Library XML with other applications”. Moreover, you have to make sure your iTunes is logged in.
How to Remove DRM from iTunes Music: Step 1> Run DVDFab 10, go to Utilities module, and click DRM Removal for Apple. Then there will be two options for you, and just choose “For Audio”.
How to Remove DRM from iTunes Music: Step 2 > Click “Add from iTunes” and go to the “Music” panel and then check the song you want.
How to Remove DRM from iTunes Music: Step 3 > Click the “folder” icon to select a directory to save the output music. And then you can click the “Start” button to begin the process of removing DRM.
For more detailed information about DVDFab DRM Removal for Apple, please go to http://www.dvdfab.cn/drm-removal.htm
SarahBishop
Re: How to Remove DRM from Apple Music?
« Reply #1 on: 30. August 2017., 02:31:32 »
In order to keep Apple Music files accessible after canceling the subscription of Apple Music and to really own the downloaded Apple Music files, removing DRM is needed. Thanks for guiding the way to remove DRM from Apple music, it is useful.
Micro
« Reply #2 on: 06. September 2017., 08:32:25 »
Step 1: Launch iTunes DRM Audio Converter on Mac. And then click Add button to add any music file you want to remove DRM. Step 2: After adding, all your added files will be listed in the main interface. Click the setting button to choose output format and output path.
krishna88
« Reply #3 on: 29. December 2017., 08:55:06 »
Hi @Micro,
Thanks for the information, it was useful for me.  :up:  :thumbsup:
mikeduke990
« Reply #4 on: 19. October 2020., 14:59:08 »
top 5 Apple Music DRM Removal free programs for your option.
NoteBurner Apple Music Converter
TuneFab Apple Music Converter
Sidify Apple Music Converter
UkeySoft Apple Music Converter
Hope this helps.
