  • Total Topics: 17012
  • Online today: 22617
Guests: 22302
Total: 22305
Author Topic: How to Export EDB files to PST?  (Read 17437 times)
hayescharlie
« on: 08. February 2019., 10:41:31 »
Enstella Systems is right option for those users who search a shortest path to export EDB files to PST. In short of time, Enstella Systems introduced a best EDB to PST converter which is built by high algorithm and data structures. Exchange users are comfortably export entire Exchange mailbox with Meta data to outlook PST format. This software allows to you select the single or multiple folders from EDB files "Which you want to convert" and then Export into EML, MSG and HTML format.  Exchange users easily reduced the large size of PST file form 1GB, 2GB, 3GB, 4GB and 5GB.
In addition, EDB to PST Converter gives multiple functions for users to easily access EDB to PST Software. With the demo version users fastly understand brilliant functions without any longer time.
Note- Get benefits of this Exchange EDB to PST Converter in lowest price at $99.
williamrhodes079
Re: How to Export EDB files to PST?
« Reply #1 on: 07. August 2019., 09:24:10 »
All User can easily export all Exchange mailboxes from a corrupt and damaged EDB file to Outlook PST by using the free conversion program name as the EDB to PST converter. This eSoftTools Exchange EDB to PST Converter software facilitates to every user to migrate all EDB file internal elements such as- emails, contacts, chats, tasks, notes, journals, appointments, and more to several unique readable file formats like PST, EML, EMLX, MSG, and HTML. Get a free trial version of this EDB to PST Tool to freely convert 25 items from every folder of EDB file to PST and other file formats.
Akshay_M
« Reply #2 on: 01. October 2019., 17:01:41 »
Convert EDB to PST Using Exchange Admin Center
This is the most direct method to export an EDB file to a PST file. Here is the process:
Step 1: Log in to Exchange Admin Center as an administrator.
Step 2: Go to the permissions tab and then click admin roles.
Step 3: Under admin roles, go to Recipient Management and click (+).
Step 4: Under the Role Group wizard, click the (+) option under the Roles option.
Step 5: Select the Mailbox Import Export Role and click the add button. Then click OK.
Step 6: Now you can see the Mailbox Import Export role under Recipient Management.
Step 7: Now, go to recipients, select mailboxes, and choose any mailbox you wish to export. Then, click more (•••) and select the option Export to a PST file.
Step – 8: Browse a mailbox which you want to export.
Step 9: Provide the path of a shared folder.
Step 10: Select a mailbox which will get an email after successful conversion. Finally, click Finish. The mailbox content will be migrated to the PST file.
Akshay
Rajat Rajput
« Reply #3 on: 21. January 2021., 07:23:18 »
Hi, if you are looking for a quick and free automated solution to convert EDB files to PST file format, then you can try out the advanced EDB to PST file converter which can easily export EDB files to PST, EML, MBOX, PDF, etc. Data Recovery Solution has offered the smart EDB to PST converter tool for FREE for 1 month.
Visit - https://www.data-recovery-solutions.com/exchange-edb-to-pst-converter.php
Chandrabhan02
« Reply #4 on: 18. June 2021., 05:29:00 »
Hi! dear users, You can use DRS EDB to PST Converter software that can convert EDB to PST Format. It is more reliable and trusty software. You should download this software and get a quick result.
know more: https://www.data-recovery-solutions.com/exchange-edb-to-pst-converter.php
tylerwhite
« Reply #5 on: 24. August 2021., 00:30:00 »
To Convert Exchange EDB files into Outlook PST format, One can go with this EDB to PST Converter tool. This application saves recover EDB mailbox items into various file formats such as MSG, EML, PST, VCF, etc. Using this tool, one can also repair their corrupted EDB files, recover deleted items, and migrate EDB to Office 365, Outlook Stores, and Live Exchange Server. Try a trial version of this tool to convert the first few items per folder. You can download this software from here:- https://www.toolsbaer.com/edb-to-pst-conversion/
Amit22Richardson
« Reply #6 on: 07. September 2024., 13:20:04 »
There are lots of people difficulty in the convert EDB to Outlook PST. Goldytools EDB to PST Converter App is a third-party utility. EDB to PST Converter Tool for migrating all EDB file into Outlook PST data such as emails, contacts, calendars, notes, etc. in the converter online. This application is proficient to convert Exchange EDB files into different file formats like PST, EML, VCF, MSG, Office 365, Live Exchange, etc. So I would like to recommend this helpful software. This is the finest GUI based app that consents you to change EDB file to Outlook in a few simple clicks. It has so various features like batch conversion, preview, saving particular emails etc. Users can use this software on a Window based operating system..
https://www.goldytools.com/convert-edb-to-pst.php
