  • Total Topics: 16978
  • Online today: 137655
Guests: 134419
Total: 134421
Author Topic: Restore corrupted OST file into PST Outlook  (Read 53621 times)
0 Members and 352 Guests are viewing this topic.
mariyajennifer
« on: 06. September 2019., 11:26:44 »
Use eSoftTools OST to PST Converter Tool to restore corrupted OST file into PST Outlook, it helps the user to migrate OST file into PST Outlook with including all folders like E-mails, Chats, Contacts, Appointments, Inbox-Outbox items, Drafts, Sent Items, Calendar, Tasks, Notes, Journal folders. OST file can easily be converted into 6+ different formats like Office 365, MBOX, CSV, EML, MSG, vCard, HTML, PST Outlook through this tool and it does not need installation of MS Outlook for converting OST file. A smart preview is shown to the user to check and confirm the conversion format. A FREE DEMO pack is available of this tool, up to 50 emails from each folder can easily be converted into all formats.
chloejohnson
Re: Restore corrupted OST file into PST Outlook
« Reply #1 on: 07. September 2019., 07:29:01 »
I would like to refer an effective OST to PST converter software. This migration software is able to export all OST mailbox item like contacts, calendars, inbox, outbox, zip attachments, appointment, tasks entries, journals, user created folders etc. It will work on all versions of MS Outlook.
Connorwalker
« Reply #2 on: 23. October 2019., 07:13:22 »
Download ToolsGround OST to PST Converter software to recover whole data in a few minutes without consuming more time and convert into Outlook PST file format. You can also convert your data into various formats like  PST, EML, EMLX, MBOX, vCal, vCard, MSG, etc.
Somit
« Reply #3 on: 26. August 2020., 11:20:54 »
For restoring OST file in PST file format, I would like to suggest SysBud OST to PST Converter. This is a single wizard tool that easily migrates the data from OST to PST format in three simple steps. This powerful tool has a bulk export feature so you can transfer more than one mailbox at a time. Plus it allows recovering corrupted, damage, and inaccessible OST file in PST file format. You can try the demo version and export 20 emails from each mailbox.
mariejohn
« Reply #4 on: 27. August 2020., 10:34:14 »
Looking for the best way toimport OST emails to PST format then here is a solution i.e. VOOK OST to PST Converter. With the assistance of this solution users can import the corrupted OST emails also to PST format. It does not allow any alteration of the OST emails throughout the conversion process. It offers the users to export mulitple OST emails in the batch with data items included in it.
OST to Outlook Converter supports all the available editions of MS Outlook i.e. Outlook 2019, 2016, 2013, etc. The entire email properties(cc, bcc, subject, date, etc.) and data integrity of the files are kept intact. It is an independent solution that does not require the instalation of any external utility.
mikeduke990
« Reply #5 on: 12. October 2020., 10:38:38 »
Use ‘Archiving’ to save OST emails to PST
By enabling the Auto Archive method in Outlook, you will be able to save the items of OST file in a separate PST file. This method helps you to keep the size of your mailbox manageable. When the size of the mailbox grows and there are multiple messages that are older and you do not require them to be in the mailbox, then you can put them in the archive folder easily. Follow the simple steps to enable auto archiving in Outlook.
Launch the Outlook application, go to File, and click Options.
Go to Advanced and click Auto Archive Settings.
Now select the number of days in which you want to run auto archiving. Select the folder to save the archived file; also, provide the archiving options and finally click OK.
Convert OST to PST without Exchange profile or server connectivity
Kernel for OST to PST is a professional tool which can freely convert 25 items from each OST folder to PST. Its advantage is that it can convert offline OST files to PST without an Exchange profile or Exchange Server connectivity. It has a highly user-friendly interface which lets the user select OST file(s), recover items including the deleted ones, and convert them to PST format. Also, it can convert multiple OST files to PST at a time. Let’s see the working of the tool:
Open the OST to PST tool. It will open a wizard to select single or multiple OST files. Select the OST file from its location.
When the tool displays the OST file content, you can choose a folder and view its content in the preview pane. To convert the OST file into PST, click the Save option on the toolbar.
To save in PST, click PST file (MS Outlook) as the Output type.
Select the filters – From, To, Subject, Folder name, Item type, and Date range.
You have the option to split the PST file after a certain size. Provide the required details.
Browse the destination path and provide the required details. Lastly, click Finish.
When the conversion is complete, the tool shows a message showing the PST file name and its location.
Hope this information was helpful to you.
To know more about Office 365 migration or to get more information on how to perform one tenant to another tenant migration visit Apps4Rent today!
lemidezcai77
« Reply #6 on: 15. October 2021., 18:14:20 »
If users aspire to move OST data files to Outlook PST and need the best solution lacking losing any data. Softaken software would guide users to try the OST to PST Converter which is most excellent to migrate OST to PST. Refer:- https://www.softakensoftware.com/ost-to-pst-converter.html
sara jane
« Reply #7 on: 03. January 2023., 07:03:13 »
I have read many other blogs, but yours is the only one that has persuaded me, and I hope that you will continue to share more insightful content with readers in the future.
Cyrilesther
« Reply #8 on: 03. April 2023., 13:48:56 »
 This is a great tool for anyone looking to recover data from a corrupted OST file and convert it into their preferred format. The free demo version is especially helpful in allowing users to test the tool before committing to purchasing the full version
rosefresh
« Reply #9 on: 09. September 2025., 11:04:37 »
You can take help of most useful ZOOK OST to PST Converter Software. This utility has direct option to convert single or multiple OST files to PST. It is well developed utility with easy-to-use interface so that users can convert OST to PST without having technical skills. After using tool, you don't need to install Outlook to convert OST files to PST format. Users can recover corrupted, damaged or inaccessible OST files. The software works with Windows 10, 8.1, 8, 7, XP, Vista, etc. Users can also try free demo version before getting full version of the software.
Download and use it Now:  https://www.zooksoftware.com/ost-to-pst/
