  • Total Topics: 16978
  • Online today: 137655
Guests: 134659
Total: 134661
Author Topic: The simple way for Lotus Notes to Outlook Conversion  (Read 8851 times)
Irisrose
« on: 24. December 2019., 10:46:51 »
If you want to switch your NSF file to PST outlook file without any data corruption. So, you should use Lotus Notes to Outlook Converter Software which is provided by eSoftTools. The main advantage of this software is to migrate NSF file to PST as well as into HTML, MSG, ICS, vCard, MBOX, EML, EMLX, and further details. It restores email components like cc, bcc, image, date, title, subject, attachments, etc with successfully working versions:- Lotus Notes NSF version up to 9.0.1, Outlook version up to 2019 and Windows version up to 10. For more information, users can download its free demo version.
harshdixit
Re: The simple way for Lotus Notes to Outlook Conversion
« Reply #1 on: 07. July 2020., 10:27:57 »
I am highly recommending the MailsSoftware Lotus Notes to Outlook converter software to perform this type of conversion process. It allows multiple NSF to PST conversion at the time and also export names.nsf file data to Outlook contacts. To find out the more features and download a free demo version from the official website.
RuskinF
« Reply #2 on: 07. July 2020., 17:32:45 »
The steps for Lotus Notes to Office 365 conversion are:
1. Backup Lotus Notes data.
2. Create Office 365 users.
3. Enable IMAP TCP/IP ports for migration.
4. Import data from Lotus Notes to Office 365.
Somit Vishwakarma
« Reply #3 on: 26. August 2020., 13:36:28 »
By using SysBud NSF to PST converter software all the user can easily migrate NSF file with inner components such as emails,contact, calendar, tasks, journals,  tasks, etc. Also after the recovery of NSF file, user can import them to Outlook. Not only this, but the tool also has multiple accessible file formats such as PST, EML, Office 365, MSG, HTML, vCard, VCF, MBOX, and Live Exchange. NSF to PST Conversion tool supports all versions of Outlook (including- 2016, 2013, 2010, 2007, 2003, and below version) and able to perform the conversion of NSF to PST without any Outlook installation.
mikeduke990
« Reply #4 on: 16. October 2020., 12:53:18 »
Steps to Convert Lotus Notes Emails to Outlook
This method involves two major steps to import lotus notes mail into Outlook 2016 and all below editions. Some of them are discussed below:
a) Export IBM Notes emails in CSV file
b) Then, Import CSV file in Microsoft Outlook
You can transfer Lotus Notes NSF to CSV format with help of following the set of instructions:
Launch Lotus Notes application on your local machine and then, open NSF database files in it
Click on the File menu and choose Export option from the displayed menu
The Export wizard window is opened in which you have to browse the desired location for an exported file. Hit on Save as a type and select Comma Separated Value / Structured Text option
Enter the name of a resultant file and choose the Export button
If you must have selected the Structured Text option then, you can skip this Step. Else, the dialog box appears in which you have to choose the options and press OK button
A Structured Text Editor box will appear in which you have to select the reliable options and click on OK
Rajat
« Reply #5 on: 25. December 2020., 08:51:46 »
Download the smart DRS NSF to PST Converter tool which is designed on the advanced algorithms and allows users to save Lotus Notes NSF files in PST, EML, MBOX, MSG, EMLX, Gmail, IMAP, Yahoo, etc. No technical knowledge is required to run the utility. The demo version can save 50 emails for free.
Chandrabhan02
« Reply #6 on: 19. March 2021., 10:00:57 »
If you are searching for the best tool that can convert Lotus Notes to Outlook then I suggested you to DRS NSF to PST Converter tool one of the best tools for you. this also provides you free demo version for users.
https://www.data-recovery-solutions.com/nsf-to-pst-converter.php
