SCF Partnership Ads
  • Total Topics: 17084
  • Online today: 26963
Guests: 23925
Total: 23926
Author Topic: McAfee 8.5i doesn't update correctly ?????  (Read 17494 times)
HISNA
« on: 28. May 2009., 06:20:56 »
Hi, having issues with 8.5i patch 8 not updating on a scheduled basis. Does anyone else have this issue? Update okay manually. TTried uninstalling and reinstalling but nothing! Any help would be appreciated .
Re: McAfee 8.5i doesn't update correctly ?????
« Reply #1 on: 28. May 2009., 08:39:32 »
Hi H.,
First (I must to ask), did you properly enable Scheduled Updating??
VirusScan Console / AutoUpdate (right click) Properties / Schedule / Enable (check is it Enabled??)
After that look around Scheduled Settings, probably there is a problem.  ;)
Let us know is this help you or We need to find some other possibilities.
cya,
Jaxn
« Reply #2 on: 28. May 2009., 23:48:30 »
Make sure you set automatic update as soon as you logon to the system at start up. I have a set up like that and never had a problem. Let m eknow if still facing issues
rzamriv
« Reply #3 on: 15. July 2009., 17:37:03 »
You can download the Superdat file directly mcafee page, restart you system, sometimes the file is corrupt and probably you have to download again.
runmartin
« Reply #4 on: 20. July 2009., 09:26:18 »
I have a similar issue with Enterpries 8.5 i . It updates OK on most of my PCs but not on one. I will not update on a manual (Update Now in the Autoupdate window). It does update if I download the sdat file.
Has anyone goe any ideas as to what may cause this?
« Reply #5 on: 20. July 2009., 14:29:31 »
Check the Services, Mcafree framework and Mcshield Service should be running
Hi Martin,
please check this advice from "zsaurabh", Topic: http://scforum.info/index.php/topic,3018.0.html
Best Regards,
runmartin
« Reply #6 on: 21. July 2009., 14:11:45 »
Hi Samker,
              I have checked that the Services, Mcafree framework and Mcshield Service are running (using Task Manager). The laptop is a Toshiba Equium running XP. I have tried uninstalling it but it does not make any difference. I have another PC running XP and it seems OK. I will try and get the error message when I try to download the latest DAT file.
Thanks
Martin
« Reply #7 on: 21. July 2009., 15:06:26 »
Hi Samker,
Thanks
Martin
Hi Martin,
please first use McAfee Virtual Technician and provide us result:
http://mvt.mcafee.com/mvt/default.asp
After that We will have more info. for resolving this problem.
Best Regards,
splur
« Reply #8 on: 26. July 2009., 17:01:36 »
I've had this problem from 8.0i to 8.7i, sometimes it updates on its own... sometimes it doesn't.  I'm not sure why, but a quick solution is to simply download the sdat.  Usually it's because I don't wait long enough for it to update itself.
georgecloner
« Reply #9 on: 28. July 2009., 18:28:26 »
Hi HISNA,
I think you may not have noticed that scheduled update for McAfee runs without showing the User Interface Window rather it runs silently in the background.  Try checking the "LOG" that is, RIGHT CLICK on AutoUpdate > View Log.
Quote from: splur
Hi splur,
Try checking your time zone synchronization, sometimes your system's time are altered from the time you connect to your domain server.
GC
