Is there some chance to We test RAM??
How do I do this? Buy some more Ram? How much would that cost roughly?
Did you try my other suggestions related to formatting problem?
I ran Dban, I hooked one of the drives to my working computer using USB and tried tuneup utility but it didn't fix the drive. I guess I will try reformatting the other drive I reinstalled windows on using the USB connector to working PC.
P.S.
Do you have on that HDDs Master-Slave pins? Check that!
None of my drives have any master/slave pins.
Also, here is another clue... I tried to reinstall again and bootup and it failed again the same way.. but there was this message I saw before too.. I will try to write out the gist of it here...
Problem detected -- Windows shutdown to prevent damage
Page fault in nonpaged area
Check new hardware
if continues disable remove new hardware
disable bios memory options - - caching, Shadowing
use safe mode to disable components
*** stop: 0x00000050 (0xFFFFFF86, 0x0000001, 0x8449DB35, 0x00000000)
