#4. Confirm the network you are connecting to. Granted, this is easier said than done. There are rogue networks called "evil twins" that criminals set up; they are designed to lure you into connecting by spoofing the name of a legitimate network. For example, you may use what you see as “Starbucks Wi-Fi” to connect while you’re sipping your latte, but you may also see a listing for “FREE Starbucks Wi-Fi.” Which one—if either—is for real? Such setups are designed to lure you in—and once connected, your data might get filtered through a criminal’s device.
Karma Samker !
