  • Total Topics: 17003
  • Online today: 18604
Guests: 18291
Total: 18292
Author Topic: How do I know if my computer has remote spy on it  (Read 10463 times)
opera
« on: 05. August 2011., 04:08:28 »
My uncle fixed my laptop about a week ago. For some reason he made his own account, password protected, and made it computer administrator, and it says that there is a program running.
Could there be spy software on it?
Yea, it is pretty stupid that he did this, ON MY LAPTOP :up:
Re: How do I know if my computer has remote spy on it
« Reply #1 on: 05. August 2011., 05:59:05 »
Hi Opera,
don't worry We'll help you to check is your PC "clean"... ;)
Please follow next instructions and provide us results ASAP
1. Scan your PC with BitDefender or Panda Online AntiVirus Scan: http://scforum.info/index.php/topic,734.0.html
2. Download & run HijackThis: http://scforum.info/index.php/topic,785.0.html
3. Provide us logs from HijackThis & AntiVirus Online Scan
I'll wait your reply (with logs).
vishwanath99
« Reply #2 on: 08. August 2011., 10:54:57 »
WHICH OS RUNNING IN UR LAPTOP.
HOW MUCH ACCOUNTS IN UR OS AND CAN U LOG IN ANY OF UR ACCOUNT.
xiaokaige
« Reply #3 on: 24. February 2012., 08:33:53 »
You can click "start"->"run". Then input "msconfig". unchecked all items in the "startup" item. If you can see an item of "nvsvc16", Maybe you uncle have install the software which in the website: http://www.mysuperspy.com/how-to-spy.htm. You only need to unchecked the item of "nvsvc16".
manual2100
« Reply #4 on: 01. February 2013., 11:22:18 »
you could install a firewall so you can check the incomming connections. there are many programs out there.
oldgreygeek
« Reply #5 on: 23. April 2014., 20:12:10 »
Two of my favorite Free AV/Rootkit killers/Scanners are:
1) TDSKiller.exe download from Kaspersky.com for latest version.  It will check and clean almost all rootkits.
2) NPE.exe download from Norton.  This one you need to be careful with.  check every entry it finds before deleting a file that is something that you need.  Google the filename if your not sure.  Every now and then it will give a false positive so you need to use common sense.
Another freebee for malware is the latest SuperAntivirus Free Edition.  this latest version works pretty good.  I use it to supplement McAfee 8.8.  You should delete it from your run box after so it will not start automatically.  I run it about once a month.
hope this helps somewhat.
« Reply #6 on: 27. April 2014., 10:35:12 »
Direct links for "lazy" SCforum's member:
Anti-rootkit utility TDSSKiller by Kaspersky: https://support.kaspersky.com/viruses/disinfection/5350
NPE - Norton Power Eraser: https://security.symantec.com/nbrt/npe.aspx
WTF is "SuperAntivirus"? Never heard... ???
All you share is useful for SCF Community, keep them coming... :up:
