  • Total Topics: 17056
  • Online today: 12867
Guests: 12840
Total: 12842
Author Topic: Plato DVD Ripper 6.73  (Read 3948 times)
« on: 28. July 2007., 19:05:31 »
Plato DVD Ripper description
An Easy to use program that allows you to backup DVDs by converting them into DivX or VCD or SVCD videos
Plato DVD Ripper is an Easy to use program that allows you to backup DVDs by converting them int DivX or VCD or SVCD video files.
Plato DVD Ripper is designed to backup your favorite DVD movie to your computer by converting DVD to AVI, DivX, XviD, VCD, SVCD MPEG1, MPEG2, MPEG4 video files, with almost same quality, but just only 10% size.
Before you rip, you can choose subtitle,audio track,frame rate and audio quality if needed. and its flexibility Output setting let you customize your generated Movie size!
Plato DVD Ripper doesn't like other DVD Ripper applications.  Plato DVD Ripper is more simply and easy to use. it just a few clicks
will completes the task of you rip DVD movies.
Since the conversion sometimes is a long time job,it could be 2-3 hours, or 5-6 hours, depending on your system configuration, with automatically shutdown feature,you can just go to sleep ,let your computer do all jobs and automatically shutdown when all jobs done.
Here are some key features of "Plato DVD Ripper":
· Convert DVD to MPEG1,MPEG2,MPEG4.
· Convert DVD to VCD,SVCD.
· Convert DVD to AVI,DivX,XviD.
· Support Ripping DVD by custom file size.
· Support choose subtitle and Audio track to rip.
· Support Setting Beginning and Ending point to rip.
· Normally, the conversion speed is 2 times of the playback speed.
· Support Automatically Shut down your computer after long time conversion.
· Best quality: the support for the latest industry standards ensures the videos you create with best picture and audio quality
Limitations:
· only 20% of the file size is converted
Download:
http://www.regnow.com/trialware/download/Download_PlatoDVDRipper_CE.exe?item=10053-1&affiliate=22260
