  • Total Topics: 15617
  • Online Today: 1411
Author Topic: Apex WMV ASF Converter 5.32  (Read 3062 times)
« on: 28. July 2007., 19:07:35 »
Apex WMV ASF Converter description
A WMV to ASF Converter that will convert your favorite movies from AVI DIVX MPEG RM RMVB MOV to WMV/ASF format
Apex WMV ASF Converter is a professional video-converter to convert video files from one format to another.
Apex WMV ASF Converter will allow you to convert AVI, DivX, XviD, MPEG, WMV, MOV, ASF, QuickTime, RM, RMVB into WMV or ASF formats.
Change the framerate, video size etc as you like.And you can set the start and end of the video clip to get your desired segment to encode.
In addition, the very user-firenldy and easy-to-use  interface lets you easily preview video files and batch convert. Very quick in
conversion speed and no quality is lost!
Here are some key features of "Apex WMV ASF Converter":
· Convert AVI, Divx,Xvid, ASF, WMV, MPEG, MOV, QT, RM, RMVB,QuickTime,MPG file to WMV/ASF.
· Support Set the start and end of the video clip to get your desired segment to convert .
· Support large video files, even large then 2GB.
· Support Batch Conversion.
· Satisfying Conversion Speed.
· Select to automatically shut down your PC after conversion.
· User-friendly UI with "easy" procedures .
Requirements:
· Intel Pentium 500 MHz or above
· 64 MB RAM or above
Limitations:
· Convert only 50% of the source file
Download:
http://www.regnow.com/trialware/download/Download_apex-wmv-converter.exe?item=14582-4&affiliate=22260
